Search found 18 matches
- Wed Jan 31, 2018 6:56 pm
- Forum: General Discussions
- Topic: Diffuse Lighting - Surface scale
Re: Diffuse Lighting - Surface scale
1. I was reffering to the "Diffue Lighting" primitive (I should be more precise :) ) 2. I also thought to be a decimal point error, but it appears in several places with several values (20, 30 etc). it is also in the "Red Wax" tutorial that follows 3. The tutorial seems to be fro...
- Wed Jan 31, 2018 5:43 pm
Hi! Another question about filters In some tutorials I found indicated for the filter "Diffuse Lighting" - parameter "Surface scale" values of 20 or 30. The related Inkscape was 0.48 Trying to reproduce the same on my 0.92 Inkscape, I found out that the max value that can be set ...
- Mon Jan 29, 2018 9:03 pm
- Topic: (solved) inner shadow in filters (version 0.92)
Re: inner shadow in filters (version 0.92)
THANKS!
Problem solved!
Problem solved!
- Mon Jan 29, 2018 7:56 pm
Hi!
It seems that Filters - Shadow and glowes - Inner Shodow has disappeared in version 0.92.
Is it in other place or renamed?
Thank you!
Thank you!
- Fri Dec 15, 2017 6:50 am
- Topic: bezier curves with ellipse shape - bug?
Re: bezier curves with ellipse shape - bug?
Yes, there are 2 options - drag a little bit the handles or increase the pattern width.
Sometimes it is working, sometimes not - because i alter my drawing.
At the end, at least I know I did not make a mistake
Thank you for your replies!
- Sun Dec 10, 2017 12:30 pm
See the upper part. If you move the handle, in any direction, in one moment the curve is coming back to normal (not twisted anymore)
- Sun Dec 10, 2017 10:03 am
Hi! After I update from 0.91 to 0.92, I found some sort of bug when drawing Bezier curves with ellipse shape. For certain angles, I obtain a strange intersection, like the curve is twisted, at one of the ends (see next drawing) wrong.png To correct this, I must move the handle, and that sometimes th...
- Wed Mar 30, 2016 6:56 pm
- Forum: Tricks & Tutorials
- Topic: Self tutorial Mesh Gradient
Re: Self tutorial Mesh Gradient
Continuing to work I "discovered" some other things and I like to share them with you here. What I write here is a mixture of test results and tutorial hope people will not be mad on me... I know that this function / tool is still in develop phase. I am aware of that. So we don't know for ...
- Wed Mar 30, 2016 6:53 pm
- Forum: Inkscape Ideas
- Topic: Gradient Mesh Tool - first results after testing
Re: Gradient Mesh Tool - first results after testing
Hope it was useful. Pleasure is mine ("To give is to have") Continuing to work I "discovered" some other things and I like to share them with you here. What I write here is a mixture of test results and tutorial, I will put them here and in the tutorials, hope people will not be ...
- Tue Mar 22, 2016 5:55 am
New discoveries: because the function is still in developing, there is no DELETE mesh line/node or UNDO (Ctrl+Z often lead to close of the Inkscape, while in mesh gradient tool). This sometimes create desperation. :) Well, OK, I create (initially for myself, but at the end I decide to make it public...
- Tue Mar 22, 2016 5:49 am
This is a tutorial that I made initially for myself, in order to not forgot what I discover in working with the Inkscape mesh gradient. The examples I present are probably not the best way of solving the tasks, but they are MY WAY of accomplishment. So if anyone can improve them with any advice, it ...
- Wed Mar 16, 2016 8:35 pm
Moini, thank you for the advice. Nevertheless, I previously found the email: inkscape-devel@lists.sourceforge.net and I sent them my comments. Only that I had to do it twice - first time my e-mail was rejected because I was included the link to this post, and it seem it is not allowed. Now I also su...
- Tue Mar 15, 2016 9:29 pm
Dear brynn I sent e-mail for developpers - thank you for the link! (yes, I know it is experimental, this is the reason it is hidden :) ) Dear Espermachine It is an amazing function! All I can say it require a lot of patience (and clicks! :) ) But, as you say - the results are stunning. In this momen...
- Mon Mar 14, 2016 5:19 pm
Hi everybody! I test in the last week the hidden Gradient Mesh Tool. :D See first picture - the results are amazing, after only one week of using the tool. :lol: tya.jpg It is a great tool and I hope it will be included in the new version. For the moment, I have 1 recommandation and 2 "bug comm...
- Thu Jun 11, 2015 7:31 pm
- Topic: Problems between versions 0.48 and 0.91 (not OSX-WIN)
Re: Problems between Mac and Windows Inkscape
Yes, it is my fault! I will change the name of the topic - if I can. In fact, based on the comments I received, it was highlighted that it is a version issue, not an OS issue
Thank you all for your support!
- Thu Jun 11, 2015 3:38 pm
Hi! Thank you for the detailed explanations - now it seems to be more clear. More, I look on my software and I find out that there ARE differences between the Inkscape versions. Even if I THOUGHT I have the latest versions, it was not the case - on mac and win 7 there was the 0.48 and on win 8 - the...
- Thu Jun 11, 2015 2:34 am
Thank you for the quick reply... Sorry, but I must confess that I did not understood. Or maybe I did no explain correct. So, I create a SVG file on Mac - roof and wall. If I open it on Mac, it looks correct. If I open it on Win 8 (SAME file), it look like parts are missing from her. More, if I open ...
- Wed Jun 10, 2015 8:44 pm
I have installed inkscape last versions on macosx and win 8. I worked some simple drawings and there was no problem between the 2 operating systems, I could see and work on the same file from both of them. But when I made just a step further and I used some gradients-textures, the following appear (...
