Search found 17 matches
- Sun Oct 17, 2010 4:05 pm
- Forum: Inkscape & Cutters/Plotters
- Topic: Why won't my picture cut?
Re: Why won't my picture cut?
Thanx for the advice. Tried one more thing before yours, put everything in one layer and combined it all and now it cuts?!?!? Go figure?!?!? Don't understand these things, but at least now it's working.
- Sat Oct 16, 2010 10:48 pm
Please can someone help me. I have reworked a number of pictures in order to cut them with my roland cutter and they have all worked well, however this one won't cut the graphic only the rectangles?!?!?!? I have redrawn it twice and still get the same result?
Thanx
Thanx
- Thu Aug 12, 2010 6:08 am
- Topic: pictures that won't cut
Hi
I hope someone can help me. I am cutting out these pictures with my GX 24. Everything is going great except now and then I end up with one picture that produces a blank card!!! I am assuming it's some kind of seting, but just don't know which one.
I am baffled, hope someone can help me.
Thanx
Thanx
- Tue May 25, 2010 12:56 am
- Topic: inkscape and the SV12
Hi there I hope someone can help. I am cuting with a roland sv 12 and inkscape on XP and then have no problem, but when I try to do the same on Vista, it only cuts about one third of the page and then STOPS!!! It's driving me insane. i have work to do and not enough hours in the day, and can't catch...
- Tue May 25, 2010 12:53 am
- Topic: Roland Plotter GX-24
Re: Roland Plotter GX-24
I cut from a inkscape using a roland sv12 without any problems on windows XP, Vista is another story altogether, just bough a GX 24 second hand, so really hope this one will work on Vista.
Good luck
Good luck
- Sun Mar 14, 2010 12:56 pm
- Topic: cutting multiple images
Re: cutting multiple images
Thanx will try that Monday morning.
Regards
Regards
- Sun Mar 14, 2010 3:17 am
Have started a new topic in help with inkscape as I cannot upload an svg file here. Don't know how to link them.
Thanx for your input so far.
- Sun Mar 14, 2010 3:16 am
inkscape cuts this image repeatedly
This post was originally started in inkscape and cutters but it will not allow me to upload an svg file there.
Inkscape keeps cutting this file more than once on top of each other when sent to the cutter, spoiling the original. Please help
- Sat Mar 13, 2010 6:47 pm
I have attached a png of the pic I am trying to cut, as I cannot upload an svg file here. There are a number of pics on a single page, three of these and two copies of another pic. It cuts just fine, but when it's finished it feeds the paper back to the start and starts cutting these images over aga...
- Thu Mar 11, 2010 4:55 am
I am cuting pics from inkscape to a roland sv 12 but it seems to be cutting the same image over itself again and again!! Does anyone know why?
Also is it possible to rotate a pic 90 degrees and still cut it with a cutter?
Thanx
Thanx
- Thu Feb 25, 2010 9:26 pm
- Topic: Can't get inkscape to cut this on my roland sv 12 please hel
Re: Can't get inkscape to cut this on my roland sv 12 please hel
Thanx for all the feedback, it suddenly came right, I think the problem was partly that I had reoriented some of the pics and partly some of the pics were too close to the border of where the cutter could cut. It's all working GREAT now. Thanx so much!!
- Mon Feb 22, 2010 8:13 pm
Seem to be getter closer here. Went back and used pics in their original orientation and they seem to work better
- Mon Feb 22, 2010 1:54 pm
Thanx. Will try unlocking. The funny thing is it seems to cut the frame and nothing else, will try doing without the frame and see what happens.
Thanx
Thanx
- Sun Feb 21, 2010 6:52 pm
Please help!!! I am new to inkscape and struggling to get it to cut on my roland sv 12. I am on a deadline for a project and it's getting frustrating. Attached is some pics I have worked on. They cut partly before I oriented them this way, now nothing happens at all. I would appreciate any help you ...
- Fri Feb 19, 2010 11:44 pm
- Forum: Inkscape & other
- Topic: inkscape and signcut
I just loaded signcut as I cannot get inkscape to work with my roland sv12 cutter. I read up on the signcut website and it seemed to be so easy to export the document to signcut, but when it gets to signcut it's just a blank page, my pictures seem to be gone!! Please help!!
Thanx
Thanx
- Thu Feb 18, 2010 4:25 am
- Topic: inkscape and roland sv12
Re: inkscape and roland sv12
Hi Brynn Everything does fit into the page border. The picture is one I have taken from the clipart gallery in inskape and reworked into a single vector line image, it's actually an alien with a dotty body. When I try to draw it I only get about 3 or 4 dots and nothing else. I have managed to print ...
- Wed Feb 17, 2010 5:27 am
I am having trouble cutting with my roland sv12 using inkscape, it only seems to cut part of the image, less than 10% and just leaves out the rest, I have tried saving as an eps file and reopening with the software provided but it will not open the file just says there is an error.
Please help!
Please help!
