Search found 149 matches
- Tue Mar 27, 2018 12:16 pm
- Topic: Weird edges on shapes
Re: Weird edges on shapes
I can, it's an extension that a user Simarilius made and then I modified it to meet my needs. It lists the node coordinates of a path. I couldn't figure out to make it process data correctly in 0.91, but I got it do it pretty consistently in 0.48. I know it all just comes down to understanding the d...
- Mon Mar 26, 2018 5:44 am
Mostly off topic: Unrelated to this problem, but personally I've been thinking of reverting to 0.48 myself. Inkscape's recent development has added vital features which require much more technical expertise than I'll ever have. It's getting to the point where complete novices can't pick up Inkscape...
- Wed Mar 21, 2018 9:53 am
It doesn't happen in 0.48; and I can even just load the same svg 0.91 saved file in 0.48 and the problems are gone, even the existing rectangles in that svg file that had problems are normal in 0.48. Guess I'll go back to using 0.48 then!
- Wed Mar 21, 2018 9:34 am
Yes , preserved Transforms are applied to the group. Info here, among other discussion: http://www.inkscapeforum.com/viewtopic.php?f=5&t=33071 Feel free to add your comments to the bug report in the linked topic. The beveled rectangle corners are due to the miter-limit set to 0 in the stroke st...
- Wed Mar 21, 2018 7:23 am
tylerdurden wrote:Please share an example svg file...
I attached sample svg in the post above. Thank you for helping out!
- Wed Mar 21, 2018 7:22 am
Looks your transformations are set preserved instead of optimized in the preferences (Shift+Ctrl+P/behavior/transforms). It was the opposite. They were set to optimized. Changing to preserved made the lines have same width all around the object. Now that issue is solved thank you! But the problem w...
- Wed Mar 21, 2018 6:37 am
Inkscape version 0.91. The edges of shapes have begun being "distorted", if you take a look at the image below. These are all new objects created from "create squares" (F4) and "Create circles"(F5). Why are the edges distorted like that? The vertical edge has larger wid...
- Sun Mar 18, 2018 3:08 am
- Topic: [SOLVED] Path effects missing?
NEVERMIND! This is solved. Im so stupid... I just had to select Envelope Deformation in the menu.... sorry. . . . . . . . . . . . . . . . . . . Im trying to follow this tutorial here, but I can't find the effects for bend path "left bend path", "right bend path", "top bend p...
- Thu Sep 14, 2017 10:03 am
- Topic: [SOLVED] Enable preview in the "Open file" dialog?
Re: [SOLVED] Enable preview in the "Open file" dialog?
That is great suv, thank you the this information!
- Tue Sep 12, 2017 11:00 pm
Re: Enable preview in the "Open file" dialog?
Thank you Brynn! It makes the save/open dialogs look ugly (windows 98 style) but it works
- Tue Sep 12, 2017 9:22 pm
Solved by brynn » Tue Sep 12, 2017 9:57 pm In Inkscape Preferences > Interface > Windows, switch to the GTK save/open dialogs." --- Version 0.48 shows a preview in the "Open file" dialog, but this is gone from following versions. How do I enable this preview for 0.91 and 0.92? 0.48. ...
- Fri Sep 01, 2017 10:03 am
- Topic: Is there a way to instantly set all selected nodes to their respective closes integer x,y positions?
Re: Is there a way to instantly set all selected nodes to their respective closes integer x,y positions?
Thanks for the reply Lazur and ~suv, that's very helpful!
- Wed Aug 30, 2017 8:27 pm
Is there a way to instantly set all selected nodes to their respective closest integer x,y positions? Say I have a path with for example 100 nodes that all are placed at fractional x,y positions (like 2.345, 4.569 etc) and want the nodes to all be placed at integer positions (like 2, 5 etc) then as ...
- Wed Aug 30, 2017 6:24 am
- Topic: Change color of "Edit path by nodes" selection outline?
Re: Change color of "Edit path by nodes" selection outline?
Just tried 0.92 and it works like in your screenshot, so I guess its a 0.91 issue. I just need to upgrade a newer version them
- Wed Aug 30, 2017 3:04 am
Sorry, of course I should have mentioned that to begin with. I am using 0.91a and Windows 10.
- Wed Aug 30, 2017 12:33 am
The color of the "Edit path by nodes" (F2) selection outline is black which means that when I use a black background I can't see the out outlined select area. How do I change the color of the "Edit path by nodes" selection box? The normal selection box of "Mark and transfrom...
- Sat Jun 24, 2017 8:14 am
- Forum: Work in progress
- Topic: Game scene wip
Re: Game scene wip
tylerdurden wrote:Hi,
Instead of a flag, maybe a windsock?
Oh yeah, that's the one to fit an airfield, thanks!
- Sat Jun 24, 2017 4:34 am
- Mon Jun 12, 2017 3:59 am
- Topic: Error "printemf::begin at EMRHEADER" when attempting to copy an object
Re: Error "printemf::begin at EMRHEADER" when attempting to copy an object
Can you test the fix version in the bug tracker, perhaps? https://bugs.launchpad.net/inkscape/+bug/1661593 jazzynico asked for someone to test, but hasn't gotten a reply since February. I could but.... seeing as the error happens on average every 14 days (but could take longer, sometimes it's a wee...
- Thu Jun 08, 2017 7:00 pm
From time to time I get this weird error (see screenshot attached) when attempting to copy an object. The only fix I have found is to restart my PC. Restarting Inkscape, loading another document, loading a new document... none of it works. Only restarting my computer works. From memory this probably...
- Mon May 29, 2017 5:24 am
Re: Game scene wip
I only know some beginner Java and Python, so I use a program called Gamemaker. It simplifies the process a lot and enables users to make games with little or even no programming skills. It's well suited for smaller games, especially 2D games. It's also very useful for prototyping a game, a basic pr...
- Sun May 28, 2017 7:39 am
- Sun May 28, 2017 7:33 am
Re: Game scene wip
Thank you Beta0, I'm really happy for the feedback! I'm trying to better myself and also to spend more time doing it. Too much procrastination sometimes unfortunately :/
- Sat May 20, 2017 11:12 pm
Re: Game scene wip
Thank you BlueKnight!
I'm thinking about having both a helicopter and a plane. Perhaps helicopter will have more maneuverability but use more fuel, while plane will be faster and use less fuel but with less maneuverability.
- Fri May 19, 2017 4:37 am
Re: Game scene wip
Thank you brynn. And a helicopter yes, that's not a bad idea at all
