Search found 54 matches
- Thu May 16, 2019 9:35 am
- Topic: Making Business card Template
- Wed May 15, 2019 9:54 am
Re: Making Business card Template
I'm using an older version of inkscape, 0.48. I don't think it's a sizing issue druban, it just seems to print a bit off and not perfectly centered.
If I upgrade to the newest version of Inkscape, does it install over the old one or do I have to uninstall the old one firest?
- Tue May 14, 2019 12:19 am
Yeah I checked the measurements to be sure they are the same. What do you mean by "setting the lines according to the Avery package? I was finally able to print them correctly from photoshop elements after I save it as a pdf file in Inkscape, but I would have preferred to print them directly fr...
- Sun May 12, 2019 10:24 am
I followed the tutorial at http://goinkscape.com/create-a-business-card-template-in-inkscape for making a business card template but when I printed it the business cards overlapped and were not within the boundries, the bottom cards overlapped the top cards and the left side overlapped the right sid...
- Wed Feb 20, 2019 10:20 am
- Topic: Alphabet Blocks
Re: Alphabet Blocks
Thanks much and thanks for the critique, they aren't suppose to look realistic, they are part of a larger comp that has a cartoon teddy bear. Thanks again
- Tue Feb 19, 2019 12:14 pm
Re: Alphabet Blocks
I don't seem to have "path effects", the closest I see in the path menu is "path effect editor" anyway thanks to durban's illustration I was able to understand and get my letters on correctly:
Thanks everyone for the help
- Sat Feb 16, 2019 12:51 pm
Re: Alphabet Blocks
Thank you for that link Byrnn, I didn't get much of it but understood enough to get the letter on correctly. Use the perspective LPE, it's much easier. Select text, then do Path > Path effects > + > Perspective/Envelope, switch to node tool to drag the nodes. Where is that located? I can't seem to f...
- Fri Feb 15, 2019 12:30 pm
Re: Alphabet Blocks
Thanks very much for the link! I tried adding a letter to the cube with the perspective extension but the letter on the left side of cube gets turned sideways, what am I doing wrong?
- Fri Feb 15, 2019 6:15 am
Re: Alphabet Blocks
Thanks, that's exactly what I want to achieve, but I don't know how to use the 3d box tool to get the perspective or shape that I want. Is there a trick to drawing the cube manually?
- Thu Feb 14, 2019 1:03 pm
Re: Alphabet Blocks
I want to know how to draw them
- Thu Feb 14, 2019 10:38 am
Re: Alphabet Blocks
Maybe there's a different name for them, the blocks toddlers play with, like this: https://pixabay.com/en/photos/alphabet%20blocks/
- Thu Feb 14, 2019 4:27 am
Alphabet Blocks
Any tutorials around showing how to make alphabet blocks in inkscape? Anyone know how to make them?
- Tue Mar 07, 2017 12:08 pm
- Topic: Making Seamless Tiles
Re: Making Seamless Tiles
Tiled clones still have the rendering gap issue. Slightly related article . Probably you don't see gaps because you are using a certain zoom level and your tiles are perfectly aligned to a pixel grid. You're right, when I zoomed out I could see lines running through but when I saved it as an eps fi...
- Sun Mar 05, 2017 4:47 am
Thanks everyone for the help. I haven't tried the extension, maybe I'll give it a try. Thanks Raspi for explaining how you would do it, I want to give it a try but I'm not sure what you mean by "displace"? The bug they're talking about was fixed because I didn't get any gaps when I cloned ...
- Thu Mar 02, 2017 3:30 pm
The tutorial specifically says to use geometric bounding, I tried the visual box option and I end up with huge spaces between the clipped tile when I clone it. What is fill pattern, do you know of a tutorial that explains it? I would love to be able to make seamless tiles in an easier way with less ...
- Wed Mar 01, 2017 6:34 am
I have been learning to make vector seamless tiles using the tutorial at http://www.verysimpledesigns.com/vectors/inkscape-tutorial-seamless-patterns.html but after I clip the tile the selection box goes beyond the tile and not rap right up close around it as shown in the tutorial (last example in t...
- Sun Jul 31, 2016 4:50 am
- Topic: Wood Grain
Re: Wood Grain
I can't look at videos, are there any online printed tutorials for making wood grain effects?
- Fri Jul 29, 2016 5:47 am
- Topic: Wood Grain
Wood Grain
Are there any tutorials to show how to make a wood grain texture?
- Sun Mar 15, 2015 10:31 am
- Topic: Clock Face
Re: Clock Face
Never mind I found it. Thanks very much.
- Sun Mar 15, 2015 10:12 am
- Topic: Clock Face
Re: Clock Face
Where do I make tiled clones? I can't seem to find that option in inkscape.
- Sun Mar 15, 2015 7:49 am
- Topic: Clock Face
Clock Face
Does anyone know how to make a clock face with numbers in inkscape?
- Wed May 28, 2014 2:12 pm
- Forum: General Discussions
- Topic: How to learn Inkscape?
Re: How to learn Inkscape?
Check out the videos at http://www.littlewebhut.com/inkscape The guy makes fantastic easy to understand tutorials, the eight ball tutorial is the one that got me started with Inkscape.
- Tue Apr 08, 2014 10:07 am
- Topic: Inkscape Download
Re: Inkscape Download
Thanks very much!
- Sun Apr 06, 2014 10:02 am
Inkscape Download
I have a new windows 8 laptop, it's 64-bit, I'm not sure what version of inkscape I'm suppose to download, is it the 64-bit version?
- Sun Jan 26, 2014 6:19 am
- Forum: Tricks & Tutorials
- Topic: Golf Ball Tutorial
Golf Ball Tutorial
Anyone know of a tutorial that shows how to make a golf ball?
