Search found 3 matches
- Sun Feb 14, 2010 6:45 pm
- Topic: How to fade edges of one object on top of another
Re: How to fade edges of one object on top of another
what about the blur control in the Fill and Stroke dialog ? You can choose the amount of blur you want for you objet and it affects its edge. I don't know if my answer is relevant but...
- Tue Feb 09, 2010 7:35 am
- Topic: how to fit Text onto perspective
Re: how to fit Text onto perspective
So, it's OK, to fit text into perspective, first select the text, then the quadrangle then go to the extensions menu => path modification => perspective and it'll work (with the 0.47 version at least...) thank you
- Tue Feb 09, 2010 7:20 am
Hello everybody, I'm trying, like the first contributor to fit text onto perspective. I did as I found on the web. Write my text with the text tool, set color, font and size. With the text selected : Path menu => object to path. First thing that go wrong : when I select the node tool, no node is sel...
