Search found 4 matches
- Thu Feb 12, 2015 3:05 pm
- Topic: Exporting A .JPG to .PNG Problem!...
Re: Exporting A .JPG to .PNG Problem!...
Ooops! Actually I'm at the wrong site, I should be on Gimp! Disregard this post! Can I have a moderator remove this thread please? Gimp is where I'm having the problem.
- Thu Feb 12, 2015 1:21 pm
tylerdurden wrote:The above image is a png... that's why the transparency is working in the browser.
Cut out, cropped and exported from GIMP.
No, no, load the .jpg image as is from Bing Images, make your changes and then export to .png and let me know if it worked.
- Thu Feb 12, 2015 11:24 am
Hi, I can successfully make the background transparent, but the problem was exporting it to .png format. Please do an export test to verify its working...
- Thu Feb 12, 2015 9:43 am
To save repeating myself I already posted on Graphic Design StackExchange and wanted to see if anyone here could tell my why this particular image I downloaded from Bing Images wouldn't export? I solved the problem with a work around using InkScape.
Thanks!...
Thanks!...
