Search found 53 matches
- Thu Jun 15, 2017 5:02 am
- Topic: Pixel Art in Inkscape
Re: Pixel Art in Inkscape
Besides my previous answers to your problem got no attention whatsoever from anyone, not even with the two feature request which would make any further actions creating pixelart unnecessary. Got no time for wasting effort. If I could give you an award for being the most helpful member, I would! :D ...
- Wed Jun 14, 2017 3:24 pm
Right now, if I had to do pixel art ... I will not use Inkscape. Because there is zero advantage to use a vector tool to do a bitmap image. At least the way you do it (individual squares) there are only downsides (antialising). I prefer Inkscape because I can easily edit each and every square to my...
- Wed Jun 14, 2017 2:54 pm
By using raster for pixelart you are limited by the renderer -blocky/non-interpolated rendering is not an option in every image viewer. Vectors can serve as a base for "pixelart" that is off of the raster range. https://s-media-cache-ak0.pinimg.com/originals/ee/bf/95/eebf95e1d61c94e18b442...
- Wed Jun 14, 2017 2:45 pm
Here is an interesting thing I found out experimenting with Paint. It doesn't like anti-aliased images. Paint somehow converts anti-aliased images to aliased images when imported into Paint. I played with this and found a way to turn my pixel art into a raster file without the spaces in-between the ...
- Thu Jun 08, 2017 6:57 am
Poison Mushroom.svg I love making/tracing pixel art in Inkscape from games and various other sources, but there is just one problem, Anti-aliasing . Anti-aliasing is great, although I do wish there was an option to turn it off when exporting pixel art to .png, jpeg, etc... In the following images b...
- Mon Jun 05, 2017 12:41 am
- Topic: Precision Issue
Re: Precision Issue
When intersected or in other way trimmed, curves in IS tend to deform in a different fashion. Proportionally, green circle`s outline is more affected with this intersection, more than the blue one - hence this slight difference. p.s. Use the Node tool to compare the both outlines. p.p.s. The differ...
- Mon Jun 05, 2017 12:02 am
Precision Issue
I need help solving this issue of not getting edges lined up perfectly. As you can see in the image below demonstrating what I mean:
Is inkscape not capable of having the edges of the two objects lined up perfectly on top of each other?
- Sat May 16, 2015 4:57 am
- Topic: Something Simple
Re: Something Simple
It's for practice and thanks for the advice.
- Fri May 15, 2015 11:31 am
- Mon Nov 10, 2014 6:48 am
- Topic: How do I recreate this?
Re: How do I recreate this?
Thank you! I now understand.
- Mon Nov 10, 2014 5:40 am
WOW that looks really good. Is it possible for you to make a quick tutorial for me?
- Mon Nov 10, 2014 5:10 am
Thanks for the help guys but I am sure there must be a better way.
- Mon Nov 10, 2014 3:04 am
I'm trying to vector this bitmap but I am having trouble with some of the curves. Here is a pic that I edited, the places where I circled red are the places I need help on. http://s14.postimg.org/ayfbpj501/565.png Here is the original image: http://s14.postimg.org/szygnbz0x/Vector_me_m1_Key.jpg
- Fri Oct 17, 2014 6:35 am
- Topic: Can you do this?
Re: Can you do this?
Other workaround: Open the xml editor (Shift+Ctrl+X), select the fill attribute in the style field, like "color:#000000", copy it, then open the search tab (Ctrl+F), paste in the style field the copied part and find all the objects with that fill at once. There are other settings as well ...
- Fri Oct 17, 2014 6:11 am
I don't see this feature. I have inkscape version 0.48.
- Fri Oct 17, 2014 5:52 am
Can you do this?
Is it possible to select objects with the same color only? I'm doing pixel art and I want to add each color to its own layer and selecting each and every piece of the same color is tedious and extremely time consuming. Is there some genius that can help me?
- Fri Oct 17, 2014 5:44 am
- Topic: [solved] How do you make round corners?
Re: How do you make round corners?
Excellent quick tutorials guys! Really appreciate it. Thank you.
- Wed Oct 15, 2014 5:52 pm
Here is an example of what I want to do:
Basically a cross with round corners. If anyone knows how to replicate this in inkscape and can teach me that would be great!
- Tue Sep 09, 2014 5:29 am
- Forum: Tricks & Tutorials
- Topic: How to make a round star with the spirograph extension
Re: How to make a round star with the spirograph extension
McRoth wrote:Hey Henri432,
That is a nice star, thank you for posting it here.
Thanks for the kind words friend.
- Tue Sep 09, 2014 5:28 am
- Topic: How would you recreate this?
Re: How would you recreate this?
Okay I understand and thanks a lot. The spirograph extension shouldn't have to make a new image every time you generate different numbers and click apply. I think this is one major problem that needs fixing because like you said the program will crash. I just hope in the next update they can fix tha...
- Mon Sep 08, 2014 6:30 pm
Hey, just to save you some time, doing trial and error with Spirograph, here are a few I've made that might work for certificate borders, in the attached SVG. WOW!!! Now I am really interested in the spirograph extension. May you please make another thread explaining the spirograph tool. I'm really...
- Sun Sep 07, 2014 3:22 pm
- Topic: Drawing Google Chrome Logo
Re: Drawing Google Chrome Logo
I would like to see the video please but Youtube probably took it down. Maybe you can upload it to another site. Like sockshare.
- Sun Sep 07, 2014 3:12 pm
This is great! I can tell your really into spirographs and I agree the spirograph extension needs some work. THANKS A LOT! I REALLY MEAN IT!
- Sun Sep 07, 2014 10:41 am
1.) Go to Extensions/Render/Spirograph 2.) Now type in these settings you see in the picture below and click apply, then after clicking apply click the close button. http://s23.postimg.org/4f9nrs7mz/Round_Star.png 3.) You will have to rotate the star to your liking. That's all. I found this out when...
- Sun Sep 07, 2014 10:16 am
WOW MUCH BETTER!
If you don't mind. How do you get the results you got. You don't have to make an in depth tutorial or anything. Just a quick tutorial will be fine if you want. Thanks Lazur URH!
