Search found 50 matches
- Sat Dec 15, 2018 2:33 am
- Topic: Changing Text Selection Color
Re: Changing Text Selection Color
OK. Thanks for the replies. Even if I knew where to find it "compile Inkscape yourself" is just not in my skill or comfort level. I will learn to adjust.
- Fri Dec 14, 2018 10:07 pm
Yes, it's really annoying. Recently upgraded from.48. I am sure it was a different color there. And, again, I realize how picky I am being when I have the wonderful product to "play" with.
- Fri Dec 14, 2018 1:27 am
Yes, this is really picky, but I do not like the highlight color that displays when I select text. Is there a way to change it?
- Thu Jul 05, 2018 12:59 am
- Topic: Document Properties Not Displaying
Re: Document Properties Not Displaying
Update! I have finally gotten my 2017 iMac and second monitor up and running. My initial problems were with my Macbook Air. Here is where I am now. I have upgraded to V.92.2. When I open Inkscape, it displays on my main screen. I can get nothing to work from here. BUT, if I immediately move the wind...
- Mon May 21, 2018 10:08 pm
Thanks for the scaling info. I restored one file and answered the questions for non-web use. The only difference I noticed was all of my square cornered squares/rectangles were rounded. A Windows techie friend asked if we can have 2 versions of Inkscape installed at the same time. I have Googled but...
- Fri May 18, 2018 9:09 pm
No matter what problems I am having right now, I am still amazed at the number of helpful people on this Forum! Best Forum I have ever used! Tyler, your reference to the 90/96 issues. Does that mean that all of my files created with V .46 will not display correctly when I open them in .91 or .92? Al...
- Fri May 18, 2018 12:29 am
Thank you for the replies and information. This is what I have done (easiest first): Lowered the resolution on both monitors - no help. Disconnected the 2nd monitor - BINGO! Now it works! Issues: I need the second monitor, so using it like this will not work. I followed the link you posted for fixin...
- Thu May 17, 2018 8:44 am
I have very happily been using Inkscape for several years. Due to a hard drive crash, I have just switched from Mac 10.6.8/Inkscape.46 to new device running Mac OS 10.13.4. Downloaded XQuartz (more on this later) and the suggested Inkscape .91. Did some spot checks on changes with newer versions. Th...
- Thu Oct 02, 2014 6:50 am
- Topic: Gradient Frustration
Re: Gradient Frustration
Such a long problem expanation for such an easy fix!!!!! Thank you! Thank you! Working perfectly again!
- Thu Oct 02, 2014 6:04 am
I have been successfully using the gradient tool to shade shapes without any problems. Yesterday, I started having a problem and think I have touched or clicked something to change it's behavior. My normal process is to make a shape and fill with color. I duplicate that shape, change the color, add ...
- Thu Sep 04, 2014 10:27 pm
- Forum: General Discussions
- Topic: Using an Image as a "Fill Pattern"
Re: Using an Image as a "Fill Pattern"
I will never again underestimate the value of posts from many years ago! I have been struggling for some time with the "residual" outside an area I have clipped. This "object to pattern" and "intersection" combo completely solves my dilemma! Thanks engs0062 for asking a...
- Sun May 04, 2014 6:30 am
- Topic: Piddley Little Ruler Question
Re: Piddley Little Ruler Question
Ahhhhhh... don't know why I didn't get this.... I work outside the page all the time. In fact, sometimes there's more outside than inside. Thanks for the revised perspective - it will most definitely help my set-up!
- Sat May 03, 2014 10:29 pm
I am obviously more "technically challenged" than I thought. I have tried to to re-set everything I know, and cannot get "into the negative". I have a default page size of 8.5 x 11. I had X and Y both set to 0 in Document Preferences. I reset Y to -11, and nothing changes on the ...
- Fri May 02, 2014 9:14 pm
Thanks for the suggestion... going to give this a try...
- Wed Apr 30, 2014 10:20 pm
In the grand scheme of using this wonderful program, this is a very small problem. But I am used to working from the upper left corner of the screen and would like that to be my 0:0 point of the rulers. I have looked all over the Preferences and Forum Info and cannot find a way to change the side ru...
- Mon Nov 18, 2013 8:54 am
- Forum: Inkscape & GIMP
- Topic: GIMP and Open Recent List
Re: GIMP and Open Recent List
Just one final post here.... At the suggestion of a response in the Apple Support Community forum, I downloaded version 2.8.6 of GIMP (had originally downloaded 2.8.4), This seems to have cleared up the "open recent" issues for Inkscape. They also suggested updating Inkscape (currently usi...
- Fri Nov 15, 2013 12:27 pm
Thanks again for your reply! Cannot tell you how your answers helped as I was sure I had created a total disaster on my Mac - and now it looks like it is more of an inconvenience than anything else. I will review the info on the links you suggested and hope I am equal to the task of writing the scri...
- Thu Nov 14, 2013 11:27 pm
Thanks for the explanation... this Forum ROCKS! Someone is always there to help!
I'm guessing there is no way to exclude Inkscape from this process... I really like using the open recent list!
- Thu Nov 14, 2013 10:48 pm
This is really strange and I'm not sure if this is the correct forum.... I downloaded GIMP earlier this week and now everytime I open GIMP, my "Open Recent" list in Inkscape disappears. The files are still there, the list is gone.... have tested several times by opening various files, quit...
- Mon Aug 19, 2013 3:05 am
- Topic: Text not printing - what did I do?
Re: Text not printing - what did I do?
Sorry for my delayed response to your replies, Lazur and flamingolady. I think my brain got lost at "alpha value" and "transparency value". The bottom line here is I can easily delete, re-enter and print the text with no problem. In fact, although I have noticed the color differe...
- Fri Aug 16, 2013 10:55 pm
OK... found the unflowed text and applied.... still did not print. Text does show up on my "print preview" - it also prints from there. Not sure what you mean by "no alpha given". Text is on the same layer as graphics... when I toggle "visible" from the little eye at th...
- Fri Aug 16, 2013 10:25 pm
Thanks for the speedy response, Format is inkscape svg.... Your post gave me an idea - saved as PDF and tried to print - still no text.
No "alt key" on my Mac... Shift ctrl C did not help.... hmmmmmm
- Fri Aug 16, 2013 9:53 pm
Finally printed a file I have been working on and the text (one short line) did not print. What I tried to do to fix it: - changed font color - did not print - changed font style - did not print - printed previous file with text - no problem - added new text and positioned it right on top of text th...
- Tue Nov 13, 2012 9:12 am
- Topic: Inkscape Crashing While Attempting to Print
Re: Inkscape Crashing While Attempting to Print
Testing day.... used a scrapbook page that I had imported 11 JPG pictures into - thought that would really test the process. I had not been able to print this at work. The original file size was just over 41MB. I used "make a bitmap copy" on three individual pics and then grouped the rest ...
- Sat Nov 10, 2012 10:50 am
I LOVE this User Forum! Always learn much more than the solution to whatever issue I have! Thanks Jelle and druban! Did not have a great deal of time to go through all of this at work today and I almost want to go in to work tomorrow to PLAY! Things I did have a chance to try/check/learn: 1. Print f...
