Search found 31 matches
- Thu May 30, 2013 3:25 am
- Forum: Inkscape Resources
- Topic: [LPE + UI] Bspline+Spirolive - 0.91+devel
Re: Bspline+Spirolive
The new release 12070 (Spirolive + BSPline) is compiled for Windows. Sorry for the delay. :-) I have compiled it in Windows 7, but it should work also in Vista and XP. Here is the link: Download: Inkscape Basic There isn't any readme on how to install. Please follow this procedure: 1. Click the link...
- Thu May 16, 2013 4:55 am
Hi. Great work! How is the release numbering determined? My "newest" install - dev. build - is "r12322" Which build is this branch based on? RGDS Ragnar I am referring to Jabier's release version. For what I have seen, it brings that number and that number appears also when you ...
- Thu May 16, 2013 3:48 am
The new release 12063 (Spirolive + BSPline) is compiled for Windows. I have compiled it in Windows 7, but it should work also in Vista and XP. Here is the link: Download:Inkscape Basic There isn't any readme on how to install. Please follow this procedure: 1. Click the link and download the file wh...
- Fri Apr 12, 2013 2:57 am
Re: Bspline+spirolive
The new release 12038 (Spirolive, BSPline with weight and move selected nodes) is compiled for Windows. I have compiled it in Windows 7, but it should work also in Vista and XP. Here is the link: Download: Basic Inkscape There isn't any readme on how to install. Please follow this procedure: 1. Cli...
- Thu Apr 11, 2013 7:12 pm
Hi. I don't really understand. The Windows link in the first post (Header post?) in this thread links to another post in this thread. http://www.inkscapeforum.com/viewtopic.php?f=11&t=13496&start=50#p53402 Is this correct? RGDS Ragnar The working links are the ones shown in that post you li...
- Tue Apr 09, 2013 11:18 pm
... I`ve went through the thread and saw ~suv`s remarks, so I`m wondering if it`s still related to the cairo, or perhaps is something else? Mesh is a great tool and it would be great to have it available. *I`m on win7/x64 As far as I know, the issue is the one pointed out by ~suv, so I guess we'll ...
- Fri Mar 29, 2013 9:01 am
Brainless - ah ok, so actually I did things correctly. I just went back into that folder and clicked on the Inkscape.exe and it worked, and the new button is there for the BSpiro etc! yay. way cool! I thought I was just adding the button to my already existing inkscape, so now I get it. I guess at ...
- Thu Mar 28, 2013 6:24 pm
Test Mesh in Windows XP, UI works but render transparent To be expected (Windows devlibs have cairo 1.11.2, which does not support rendering gradient meshes on canvas (this requires cairo 1.11.4 or later) - see links in my earlier comment). Thanks ~suv. Now I understand better what you meant for &q...
- Thu Mar 28, 2013 2:48 am
I am really confused. I have tried right now from home and the link points to the correct file while when I have tried to download from the office I got an older version (that's why there wasn't the mesh gradient). The only difference is that in the office I have WinXP and here Win7. If someone has ...
- Wed Mar 27, 2013 9:33 pm
@brainless Maybe you have a devlibs updated, when start compiling in the early bspline, whith the problems with Druban? Before compiling, I'm always updating devlibs so the last version compiled have devlibs as they were on last Sunday. I added a PPA for debian/ubuntu. The package is inkscape-bs (r...
- Wed Mar 27, 2013 8:45 pm
Remark: I don't know why, but that version does not include the mesh gradient. Now I haven't under my hands my PC, but this evening I will check and maybe I will replave the file with the correct one. AFAIK the version of cairo included in the current devlibs for Windows is too old (to actually ena...
- Wed Mar 27, 2013 6:23 pm
I'm having troubles trying to install. Am following Brainless's instructions but can't figure it out. (I have Win 7 BTW), thought I extracted ok, used 7 zip to extract the files, but it put them all in the main Download folder, and some of the folders don't have any files in them, so it's not going...
- Tue Mar 26, 2013 7:37 am
Re: SpiroLive + BSpline r12024
The new release (Spirolive, BSPline with pencil support) is compiled for Windows. I have compiled it in Windows 7, but it should work also in Vista and XP. Here is the link: Download: Basic Inkscape I have tested on Windows 7 and it works nicely. It should also on Vista and XP. There isn't any read...
- Thu Mar 07, 2013 3:55 am
Re: SpiroLive + B-Spline@BPower branch
The new release ( BSpline@BPower ) is compiled for Windows. I have compiled it in Windows 7, but it should work also in Vista and XP. Here is the link: Link no longer available. Please, check here I have tested on Windows 7 and it works nicely. It should also on Vista and XP. There isn't any readme...
- Wed Mar 06, 2013 6:03 pm
Re: SpiroLive+B-Spline@BPower Branch
Hi all.
After Jabier's new release of the BSpline tool, I am planning to compile it for Windows later this afternoon. So, it should become available within today.
- Sun Feb 17, 2013 6:12 pm
- Forum: Inkscape Ideas
- Topic: Acad-plugin for Inkscape
Re: Acad-plugin for Inkscape
Ok druban. I will try to go through. Just a question: could you tell me what do you mean with "Old"? Does it mean that Inkscape has another newer tool able to the same?
Edit: I have managed to compile a version with (i think) all of those LPes included. You can find it here
- Sat Feb 16, 2013 7:38 pm
Hi Brainless, I can point you to the page with the last development version (r11789) that Uwe Scholer compiled containing these experimental LPEs for Windows. You can try out the draft version of these path effects but do note that some of them don't work at all and will immediately crash your Inks...
- Sat Feb 16, 2013 6:06 pm
I'd say start with the link in the op, and go from there. I haven't heard of anything, but that's where I would start looking :D Oh, trust me brynn. I have investigated all the possible sources of info and I also noticed that on Launchpad there is a blueprint on the topic marked as essential and on...
- Fri Feb 15, 2013 6:26 pm
Hi everybody.
Is this project still alive or is it dead/abandoned?
- Thu Feb 14, 2013 6:25 am
Re: B-Spline + SpiroLive Branch
Nice to know. So, I can tell my lawyer that it isn't necessary to prepare any defense
- Thu Feb 14, 2013 5:50 am
Hi druban. Very beautiful that blue screen. I like it very much :-) That issue I also had when I tried to open Inkscape from the console. It is what I mentioned in my post when I declared that there are errors in installing some fonts. At the very beginning I thought to fonts related to Adobe Master...
- Thu Feb 14, 2013 4:01 am
Well, i was seduced by the prospect of using bsplines and livespiro and now unfortunately I can't use any!! of my development versions -when I try to open document properties or preferences...it crashes!! Nothing to do with your compiling... eventually I will track down the problem.... EDIT: All In...
- Wed Feb 13, 2013 8:50 am
... have you looked into the preferences saving issue at all? I can save prefs from my other versions but trying to saveprefs from the bspline and the last development version now ALWAYS crash inkscape. Any ideas? I used to be able to save prefs from development versions without any trouble... I ha...
- Wed Feb 13, 2013 8:29 am
Brainless - thanks so much for writing Windows 7 instructions! when I feel better I will attempt to install this, can't wait, but have other things to deal with first. Brainless wote "Of course is just my opinion and it comes from what I draw in Inkscape: to me the key point is to be accurate ...
- Wed Feb 13, 2013 4:40 am
No, they are not connected to BSplines. They are a little off topic. 1. Trim: yes, but addng manually is very often not so accurate. Consider that sometimes I have to care of a precision of less than half a mm due to scale factors. 2. It's true, but double clicking add a node only to one of the path...
