Search found 138 matches
- Wed Dec 05, 2018 11:53 pm
- Topic: Trying to copy a parabolic curve from a PDF
I want to use Inkscape to design parts of an antenna. The parts will be cut from acrylic on a laser cutter and use to hold together some sheet metal and wire which will form a reflector and the antenna itself. The problem I have is creating the parabola from the PDF supplied here: https://drive.goog...
- Sun Aug 05, 2018 8:39 am
- Topic: Bug? Object looks like a circle but should be a square
Is this a bug? When I open a file I started some time ago, created using version 0.92.2 (problem still occurs when opening file in version .3), the object I expect to look like a square looks like a circle. If you look at the position of the circular handle, it says it should be a square. If I move ...
- Fri Jul 13, 2018 3:30 am
- Topic: Multiple text boxes selected but only one affected by font changes
I exported some charts from Excel as PDFs and imported them into Inkscape 0.92.3. I removed manual kerning from all the text. Now I'm trying to change the font size for the chart titles but for some reason only one of the selected text boxes is affected. How can I change all the boxes at once? Thank...
- Fri Jul 13, 2018 2:16 am
- Topic: Overlapping letters in textbox from imported PDF exported from MS Excel [SOLVED]
Re: Overlapping letters in textbox from imported PDF exported from MS Excel
Perfect! Thanks very much, Xav!
- Fri Jul 13, 2018 1:44 am
I exported some charts from Excel 2016 as PDFs. I imported the PDFs into Inkscape 0.92.3 and when I try to type in the text boxes, the letters I type overlap each other. In the below screenshot I placed the cursor after the 'l' in 'manual' and typed XYZ which overlap the l and the space after the l....
- Sat Jun 30, 2018 7:36 am
- Topic: Automatically select all thin lines [SOLVED]
Re: Automatically select all thin lines
That's awesome, thank you both for your responses! What a great feature that "select same" is.
- Sat Jun 30, 2018 4:35 am
I made some plasmid maps in a different software but the software makes some really thin lines for labels with no way of setting their thickness. Is there some way I can automatically select all these thin (0.088 mm) straight lines so I can adjust their thickness simultaneously? Maybe it would be an...
- Mon Jun 18, 2018 11:56 pm
- Topic: Change font size but keep text centred in its current position
I would like to reduce my font size but keep the text centered in its current position. When I reduce the font size the text stays aligned to the left and bottom of its previous position. What is the easiest way to achieve this?
- Wed May 02, 2018 11:04 pm
- Topic: Possible bug makes objects turn black on undo operation
Re: Possible bug makes objects turn black on undo operation
Thanks for the workarounds. I made a bug report for the issue: https://bugs.launchpad.net/inkscape/+bug/1763730
- Fri Apr 13, 2018 11:47 pm
I think I have found a bug in Inkscape and I'd like someone else to confirm it and then I'll make a bug report. My file is available here: https://www.dropbox.com/s/j8ad768rbi29qtr/Natural%20CRISPR%20schematic.svg?dl=0 I created the file using an online service to convert an MS PowerPoint file into ...
- Fri Mar 30, 2018 1:32 am
- Topic: Resizing bitmap images in Inkscape - effect on quality?
I'm preparing my thesis figures in Inkscape and my figures sometimes include bitmap elements. I'm wondering what happens when I resize bitmaps in Inkscape; does it record the original bitmap so resizing it continually doesn't cause it to degrade? That's what appears to be the case from my messing ar...
- Tue Feb 06, 2018 10:50 am
- Topic: [SOLVED] Flatten beziers arbitrary minimum limitation produces rough result
Re: Flatten beziers arbitrary minimum limitation produces rough result
I found that selecting all the nodes and then using the 'insert new node into selected segment' function three times prior to flattening improved the outcome.
- Tue Feb 06, 2018 10:25 am
I am trying to prepare DXF files to use in openSCAD. There's an Inkscape extension but it's six years old. I need to remove "splines" by going Extensions > Modify paths > Flatten beziers but the minimum value of 0.1 still produces a rough result (the default value of 10 produces an absurd ...
- Tue Feb 06, 2018 10:19 am
- Forum: Feedback & Suggestions
- Topic: Search error
Search error
I was trying to find out what my username is to log in and I got this rubbish response (no way is seanspotatobusiness a common word on this forum):
- Sun Nov 12, 2017 8:45 pm
- Topic: Making hexagonal honeycomb lattice
I'm trying to make a honeycomb lattice. I tried following both versions of the instructions here but I end up with overlapping. How do I achieve the lattice? I don't know how to predict the result of the values entered into the tiled cloning interface.
- Tue Oct 17, 2017 7:49 am
- Topic: Why isn't pressing HOME always enough to get layer to top?
Sometimes it is not enough to move a layer to the top of the stack by pressing HOME and I have to move an offending layer down as well. Why is this?
- Sun Oct 15, 2017 7:39 am
- Topic: Change colours of fill pattern
I used the fill pattern "checkerboard" but it's black and white and I want different colours. Is there a means to change the colours? I want multiple checkerboard patterned objects in different combinations of colours. I'd rather not have to make my own pattern because that completely defe...
- Fri Oct 06, 2017 4:15 pm
- Topic: Why does sometime Home not work but Page up does?
Why does sometime Home not work but Page up does for arranging Z order?
- Fri Oct 06, 2017 4:06 pm
- Topic: Creating a second set of tiled clones deletes the first set?
Creating a second set of tiled clones deletes the first set? Is that deliberate? It doesn't seem like a useful "feature" to me. I wanted to make two sets of tiled clones from one parent.
- Fri Oct 06, 2017 4:04 pm
- Topic: Fill bounded area not doing a good job
Re: Fill bounded area not doing a good job
Literally everything that a computer program does is maths!
- Thu Oct 05, 2017 1:29 pm
- Topic: Dragging bitmap images from browser to Inkscape?
I would like to be able to drag bitmap images from my web browser into Inkscape. Is that possible?
- Thu Oct 05, 2017 1:11 pm
- Topic: How to view multiple tool windows at the same time?
I used to be able to have multiple tool windows (e.g. align, objects, layers) open at the same time. Right now, I can only open one and when I do so, it collapses the previous. Dragging the bunch down just adds a load of wasted space to the bottom of the list. How do I get them to share that right h...
- Thu Oct 05, 2017 1:06 pm
- Topic: Where is the object manager window
Re: Where is the object manager window
In version 0.91.2 it's at Object > Objects.
- Thu Oct 05, 2017 12:27 pm
- Topic: Replace multiple objects
Re: Replace multiple objects
Thanks. Unfortunately, although those unique names enabled me to identify the code that define one of these objects, it's also going to prevent me from using the find and replace feature. This is way too complicated. This method should be quicker (uses "exchange positions of selected objects&qu...
- Thu Oct 05, 2017 11:25 am
- Topic: How to separate shapes made by Boolean difference so I can colour them separately?
Re: How to separate shapes made by Boolean difference so I can colour them separately?
Thanks, Tyler; that was exceedingly sneaky, even for a segment!
