Search found 5 matches
- Sun Nov 23, 2014 1:05 pm
- Forum: Inkscape Ideas
- Topic: View mode in Inkscape
Re: View mode in Inkscape
You can join the conversation on the mailing list: http://sourceforge.net/p/inkscape/mailm ... /33070462/
- Sun Nov 23, 2014 12:08 pm
Shift+F11 is the answer
- Wed Nov 19, 2014 2:54 pm
Hi everyone, I have an idea: add a view mode in Inkscape. That means with one click, you will hide all menus and panels; another click, everything appears again. Easy come, easy go. This has some advantages: ⋅ Load time of Inkscape and Inkview are not so different. ⋅ Inkview is l...
- Thu Oct 30, 2014 12:24 pm
- Topic: How to change stroke width of image made by drawing in iPad?
Re: How to change stroke width of image made by drawing in i
Thanks brynn, it works
- Thu Oct 30, 2014 4:35 am
I have a drawing using Adobe Ideas app in iPad, then export it to PDF to open it with Inkscape. It is a vector image since I can enlarge it as much as I want. However the width of the stroke too big when I enlarge so I want to reduce it. When I double click on it, the result appears as the picture b...
