Search found 218 matches
- Wed Jul 17, 2013 7:31 am
- Forum: SVG / XML Code
- Topic: [Solved] <inkscape:grid (Code-question)
Re: <inkscape:grid (Code-question)
1) this is so that Inksacape can remember the setting you use when/if you set up the "grid" guides: Document Properties (ctrl+shift+P) -> Grids. Toggle on/off using # 2) Properly name-spaced xml elements should not be causing problems with the w3g validator [well, they might, but it is val...
- Mon Apr 15, 2013 5:29 pm
- Topic: Matrix transformation
Re: Matrix transformation
(By chance did you read some of my previous replies? I assume you did seeing as you seem to be nearly there !) The Key thing to note is that the transform object transforms the whole co-ordinate system, not just the object. There is a very subtle difference. The thing to note is that the matrix tran...
- Thu Dec 06, 2012 12:15 am
- Topic: Duplicating gradients
Re: Duplicating gradients
If your gradients are solid i.e. they do not contain transparencies, then you can assign the stroke the same gradient. 1) Select object. 2) Open fill and stroke dialogue 3) Under Stroke Paint, select gradient option, select the same gradient as the fill paint uses. 4) Done. The reason this does not ...
- Mon Sep 17, 2012 4:36 am
- Topic: How to combine translate() and rotate() into matrix()
Re: How to combine translate() and rotate() into matrix()
Well, it has been a while since I last had to do matrix maths, or looked into how it applies to svg, Would either of my previous answers to this question help: 1) http://www.inkscapeforum.com/viewtopic.php?f=16&t=10550&p=39202#p39202 2) http://www.inkscapeforum.com/viewtopic.php?f=16&t=5...
- Sun Jun 17, 2012 10:28 pm
- Topic: Any tool for translating text inside SVG XML?
Re: Any tool for translating text inside SVG XML?
AndyFitzsimon has put together one tutorial on how to do this, unfortunately having to use the internet archive due to spam problems... http://web.archive.org/web/20080415092335/http://andy.brisgeek.com/archives/45 or in Russian... http://linuxgraphics.ru/articles.php?article_id=33 Not sure how much...
- Sun Apr 15, 2012 1:22 am
- Forum: General Discussions
- Topic: [SOLVED] How do I replicate Inkscape's bitmap tracer?
Re: How do I replicate Inkscape's bitmap tracer with Potrace
Not an expert, but... Potrace only does black and white? I had the impression that potrace and Trace Bitmap were basically the same thing. Potrace only does black and white. Inkscape has added several pre-processing steps that enable it to do the fancy traces, basically doing the colour prossessing ...
- Fri Mar 09, 2012 8:59 am
- Topic: Arm based distro
Re: Arm based distro
Just checked the Debian package archive: http://packages.debian.org/sid/inkscape and it has builds for x86 and Arm, and more... So yes.
- Wed Feb 15, 2012 9:43 am
- Forum: Inkscape Ideas
- Topic: Kaleidoscope Effect
Re: Kaleidoscope Effect
I remember making that! Glad to see that it got some use
- Thu Jan 12, 2012 5:37 am
- Topic: svg in html/js
Re: svg in html/js
Not legal as is. In HTML 5 you are nearly correct see this: http://www.tutorialspoint.com/html5/html5_svg.htm basically you have to add the svg namespace element. Otherwise it is a bit of a mind field, tav has done a fairly good job of summarizing the options: http://tavmjong.free.fr/SVG/SVG_IN_HTML...
- Sat Dec 31, 2011 11:55 pm
- Topic: Illustration from microscope live view?
Re: Illustration from microscope live view?
Not being well versed in live view for microscopes, but recently finishing Uni, I thought I would list the pieces of software that I thought could match / help / if you asked people involved would be more knowledgeable about requirements/ solutions: http://gwyddion.net/ Mostly deals with AFM / scann...
- Sat Dec 31, 2011 9:45 am
- Topic: Inkscape app for android?
Re: Inkscape app for android?
No, there isn't an android version. Inkscape has Mac/Linux/Windows version as well as a portable apps version (one you can put on a usb stick to use without installing). Making a version for a different platform takes a lot of work, especially for mobile platforms as they are more prescriptive in ho...
- Sun Dec 04, 2011 8:25 am
- Topic: Extracting data from graph vectors
Re: Extracting data from graph vectors
You can see the vector data used to create lines but I'm not sure if the format will be useful for your purposes. To view the vector data (SVG format) select the line then open the XML Editor on the the command bar, 4th item from right hand side / ( Shift+Ctrl+X ). You can see the value pairs in the...
- Mon Nov 28, 2011 4:31 am
- Topic: Joining or connecting lines
Re: Joining or connecting lines
Could you not just scale the original pentagon by 50% (Object -> Transform). Anyway, you could probably do it by selecting two lines at a time and using the Align and Distribute dialogue ( Shift + Ctrl + A ) using the option to align to the biggest object / last selected and the relative to bottom/t...
- Sat Nov 26, 2011 4:27 am
- Forum: Off topic
- Topic: [SOLVED] Drawing tool
Re: Drawing tool
This forum is for the discussion of Inkscape ( http://www.inkscape.org ). The icons on the right in the post editor are there to help people give instructions on how to use Inkscape. NOT for drawing in this forum. For example: 1) Use the select tool ( :tool_selector: ) to select the object. 2) Then ...
- Wed Nov 23, 2011 10:48 am
- Topic: SVG <use> with JS variables
Re: SVG <use> with JS variables
Well, I have managed to adapt the second version to a working state ;-) , the couple of problems I found was not setting all the attributes by using the name space reference and a couple of other things. I ended up returning to the original def section rather than creating it in javascript. Trying t...
- Wed Nov 23, 2011 12:42 am
Defiantly text/ecmascript ... Also when I run it through firebug (getfirebug.com) for firefox; line 50 says this: Node cannot be inserted at the specified point in the hierarchy [Break On This Error] svgdoc.appendChild(usea); js_test.svg (line 50) so I believe that this is why carto.net uses this do...
- Tue Nov 22, 2011 11:44 am
First mistake (in the new version); <script type="image/svg+xml"> (line 12) is incorrect... it should be: <script type="text/ecmascript"> . I think that is a big one ;-) Second. the if statement is incorrect; it requires {} brackets around the statement to be performed Oh, and th...
- Sat Nov 05, 2011 7:40 am
- Topic: Help develope a techinque to make this effect possible
Re: Help develope a techinque to make this effect possible
I have done this before in Inkscape. The method I used was to create a series of circles with set radiuses (100px, 80, 60, 40 and 20) align and distribute them so that they are all centred. Convert them to paths, combine them all ctrl+k. Make a duplicate copy. Each circle should be made out of 4 seg...
- Mon Oct 31, 2011 10:51 pm
- Topic: Applying Matrix from svg parsing.
Re: Applying Matrix from svg parsing.
In your case if you only have scaling and translations (with no rotation or skew); then things simplify a bit. From the 2 matrixes in the first post, when multiplied gives: [ 1 0 tx ] [ sx 0 0 ] [ sx 0 tx ] [ 0 1 ty ] * [ 0 sy 0 ] = [ 0 sy ty ] [ 0 0 1 ] [ 0 0 1 ] [ 0 0 1 ] I didn't use the Pythagor...
- Mon Oct 31, 2011 10:09 am
Have a look at this answer: http://stackoverflow.com/questions/4361242/extract-rotation-scale-values-from-2d-transformation-matrix Not all values of a,b,c,d,tx,ty will yield a valid rotation sequence. I assume the above values are part of a 3x3 homogeneous rotation matrix in 2D | a b tx | A = | c d ...
- Sat Oct 29, 2011 12:39 am
- Topic: How can I create an arrow with a contour for visibililty?
Re: How can I create an arrow with a contour for visibililty
1) Create a line 2) Add arrow marker on the line: select line, Object->Fill and stroke->Stroke style. Increase the stroke width to your liking. 3) convert the path into an object (Path->Stroke to Path) 4) Union the path and the marker to each other (select both, Path->Union) 5)Change the new objects...
- Tue Oct 25, 2011 4:38 am
- Topic: Inkscape with 98se
Re: Inkscape with 98se
Inkscape 0.42 ( http://sourceforge.net/projects/inkscap ... pe/0.42.2/ ) was the last to support Windows 95/98/ME. See here: http://wiki.inkscape.org/wiki/index.php ... ME_support (the version that dropped the support).
- Mon Oct 24, 2011 10:16 pm
- Topic: Help me with my 1st Inkscape Project
Re: Help me with my 1st Inkscape Project
1. I've made a cloud and then got it duplicate, now I need the second cloud to look squashed under load but all I can do is resize it and move it. I need only the top part to get resized (I hope am making sense) 2. I've made a speaker I need to trim off abstractly the lower portion of it (just a li...
- Fri Oct 21, 2011 9:36 am
- Topic: cant get cmyk value to work
Re: cant get cmyk value to work
The problem is that Inkscape internally stores all colours as RGB and converts the values you enter into the RGB colorspace. The second problem is that there is no one "correct" CMYK colourspace, and there are multiple ways to convert between RGB and CMYK and back, and the values you enter...
- Tue Sep 27, 2011 7:55 pm
- Topic: F7 and Zoom
Re: F7 and Zoom
Ok, things you need to make this work: The verb (Actions) name: SP_VERB_ZOOM_SELECTION, "ZoomSelection" (from http://bazaar.launchpad.net/~inkscape.dev/inkscape/trunk/view/head:/src/verbs.cpp) The KeyCode: #define GDK_KEY_F7 0xffc4 (from http://git.gnome.org/browse/gtk+/plain/gdk/gdkkeysym...
