Search found 13 matches
- Thu Sep 19, 2019 3:42 am
- Topic: realistic pen pencil chalk line help
Re: realistic pen pencil chalk line help
Thank you so much again for your time and help. Our business is mobile WoodFired pizza so I am usually swamped till Tuesdays. I believe after I made my last post I went in to the file and tried to see what the heck was all the data. When I originally traced the image I made 2 layers one ORIGINAL the...
- Fri Sep 13, 2019 1:24 pm
So some brief reading on GIMP I now understand more completely your "unless you have the need for scaleability" So if gimp is good for the effect but not scaleability then what is my option here? Im not sure how to "start big" in inkscape could you advise? A quick attempt to scal...
- Fri Sep 13, 2019 12:47 pm
Thank you. I was thinking the same thing about the width of the lines and I believe you are absolutely correct. Part of this conversion is motivated by the need for scaelability the small original logo actually has achieved a very nice "vintage" feel to it that goes well with our Old World...
- Fri Sep 13, 2019 5:39 am
Hi there I have searched and come up with several examples of what Im looking to do but I just cant seem to figure out why i can not get it to work. I have an old hand drawn image of my daughter that I created years ago for part of our logo. The original is long gone and all I have now is a scanned ...
- Thu Nov 29, 2018 5:50 am
- Topic: separating clipping from parent image
Re: separating clipping from parent image
Thank you for your reply. I'm not sure we are on the same page but maybe? I wish I knew how to post pic it would be much more easy. Ok so imagine a hand drawing with 2 oranges on the bottom and an apple on top of them. What I did was outline and clip the apple from the oranges- select the 2 parts an...
- Wed Nov 28, 2018 1:06 pm
Hi all I have searched and searched for this solution but did not find it. Perhaps my terminology is incorrect. I have an logo IMAGE that I have cut apart (clipped) outlined with bezier tool-select- clip-set. The clip worked well but some how Im still connected to the parent image. I cant see it and...
- Wed Feb 17, 2016 3:28 am
- Topic: text to path not working
Re: text to path not working
THANKS ALL
- Tue Feb 16, 2016 2:15 pm
thanks for you help. Re-reading my question I realize I was not very clear. So for future reference, and I realize without more information you can only speculate but do yo think it was because of the file size of the image Im working on it was doing that? I mean on a clean page it does put the text...
- Tue Feb 16, 2016 7:49 am
tried to upload it says file too large and I have no idea how to reduce it. sorry
- Tue Feb 16, 2016 7:32 am
thank you I was creating this curved text while working on a sign design and was just doing it off to the side on the same page. Since I deleted my attempts at the curved text after asking the question here I needed to create a new file to reproduce the issue and send here. Well now it worked just f...
- Tue Feb 16, 2016 7:03 am
I realize this is an old post but i have read all a could find including the manual on this procedure and did not find a solution. I am trying to put text on a path, for now the "path" is just a simple curve almost a half circle. I have done this before about a month ago and it worked fine...
- Sun Nov 22, 2015 8:08 am
- Topic: Could not connect to the open clipart library
Re: Could not connect to the open clipart library
Thank you
It appears as if it was created to access the OCA right from the program and just search and download or add from there.
Is there even a way to save something created in Inkscape to a "library" so for example images I use often I can just access and add?
- Sun Nov 22, 2015 7:10 am
Hi all I am a new user for private use home/ business related artwork items. I have searched on this site and google and was unable to find an answer to my question. I have found questions close but they were for an earlier version. I recently downloaded this version:0.91 (r13725) I added the "...
