Search found 51 matches
- Thu Oct 28, 2010 8:19 am
- Forum: Inkscape & Scribus
- Topic: How to paginate in Scribus?
Re: How to paginate in Scribus?
Thank you, it was a good help.
- Tue Aug 04, 2009 8:30 am
- Topic: Pale print
Re: Pale print
Thank you brtkr. I use Windows Vista now. Your help is valuable.
- Fri Jul 03, 2009 1:09 am
Now I am sure that this is the only (English) forum abut Scribus in the whole world. After my question Nobody konws any special Scribus-forum? Google is your friend I've got a mail so I could find the Scribus-forum on http://www.open-of-course.org/courses/mod/forum/view.php?id=406, but it is unpossi...
- Wed Jul 01, 2009 6:36 pm
- Topic: Pale print
Pale print
I get very pale print from Scribus. Can you give me any advice, how shall I adjust the color management in the preferences? Is there any optimal constellation? I saw that Littlecms would help, I downloaded it but I cannot install it.
Can you help me with this too?
- Wed Jul 01, 2009 5:57 pm
- Topic: Why is it dashed?
Re: Why is it dashed?
Thank you.
- Tue Jun 30, 2009 6:15 pm
- Mon Jun 29, 2009 10:18 pm
Thank you, I have heard about Google :) ... Naturally I searched forum there. The first one you get is so special that there is not possible to wright any message, even if you are registrated. The second is German. There are several German scribus-forums in german, maybe it is time to learn German :...
- Mon Jun 29, 2009 5:17 pm
I have a lot of other problems too in Scribus, e.g. to apply a template. Nobody konws any special Scribus-forum?
- Sat Jun 27, 2009 8:23 pm
- Topic: Impossible to get sharp corners
Re: Impossible to get sharp corners
Thank you. Now I changed from Linux to Vista and I have not the same problem.
- Sat Jun 27, 2009 8:17 pm
Please, tell me how to paginate in Scribus. (I know this is not too much with Inkscape to do but I cannot find a real Scribus-forum. Maybe you can give me an adress too.) I have tried like this: I choose the pages in Preferences>Sessions. Then I make a text-field, push CTR+# and I cannot see anythin...
- Thu Jun 04, 2009 7:56 am
When I make a rectangle, I get rounded corners and it is impossible to get sharp corners. The cornershape handles moves inside the shape and the Square Corners button doesn't work. I've read the manual. Is this a bug?- Thu Jun 04, 2009 7:43 am
- Topic: Bus stops with name
Re: Bus stops with name
Thank you.
- Mon May 25, 2009 3:36 am
I suppose that this problem is related to Linux. I have the file on USB and when I open the same file in Windows I have the images. When I open it in Linux, I have not. Why?
- Sun May 24, 2009 8:57 am
Linked image not found
How big is the project? Excuse me I didn't answer yet. It can be a big project or nothing. This is only an idea yet, but maybe it will be accepted and then it will be a huge project. However I've got a curious result. These are not lines what I wrote about, but there is some connection with that id...
- Thu May 07, 2009 7:09 pm
- Topic: Splitted path as different objects
I want to split a path and give different line style to the two pathes. But I cannot because they are still the same object. How can I change them individually?
- Thu Apr 30, 2009 5:09 am
Thank you that you made efforts. Maybe this is an idea for coming versions. I shall draw several hundred lines on a map and sometimes want select and modify only one of them. Does it make any difference if I open a new layer for every line or I just draw the lline? I suppose, it will be the same res...
- Thu Apr 30, 2009 2:15 am
I illustrate what I want very simply: http://forumbilder.se/thumbs/2f9200962400Pac23.jpg The second line is modified from the first line. I should like to connect the little green lines and the names to the path so I need not pull them one after one, but it would be enough to pull the path, they wou...
- Wed Apr 29, 2009 3:21 pm
Yes, but when I do it, the text doesn't hang on when I move the path.
- Wed Apr 29, 2009 7:28 am
Bus stops with name
I draw paths on a map-background. They are bus-lines with dots or little lines as bus-stops. I want to write the name of the bus stops perpendicularly to the path and I want that they will keep the position to the path even I move it
. How can I make that connections?
. How can I make that connections?- Thu Feb 14, 2008 2:24 am
- Topic: Hole in a group
Re: Hole in a group
Thank you, kelan. It was not so simple as I beleived, that was simple and sophisticated at the same time.
I have discovered that my question went lost. I would place it into Help with Using Inkscape.
- Wed Feb 13, 2008 9:06 pm
Hole in a group
Hello, it was a long time ago. Now I should like to make a ring again with a hole in the middle. It works with Path>Difference if it is only 2 ovals. But if I want to make a ring looks like a road with broken white lines, that is no problem with several scaled ovals with stroke stiles. I smelt them ...
- Fri Jan 11, 2008 8:35 am
- Forum: General Discussions
- Topic: Ring around a word?
Re: Ring around a word?
I tell you promptly, that this is not my idea. This is not a project I will be proud of. :| My friend want have a logo for his company in this style. I don't beleive it will be nice, but I want to show him that it is a wrong idea... Anyway, I try to make this according to his drawing. I have the res...
- Thu Jan 10, 2008 4:50 pm
- Wed Jan 09, 2008 5:14 pm
Ring around a word?
Can I set a ring around a word? I mean "3D", so the backside of the ring shall appear among the letters and the frontsize before them.
- Sat Jan 05, 2008 6:39 am
- Topic: Word-perspective
Re: Word-perspective
Yes!
Thank you capnhud, your advice worked! And thank you prkos for your answer too!
