Search found 982 matches
- Tue Nov 05, 2019 9:51 pm
- Topic: Help me colour my fish... Bezier pen, and then filling!
Re: Help me colour my fish... Bezier pen, and then filling!
Most likely you kept the fish as a group - hence path operations not working as expected.
- Sat Nov 02, 2019 10:29 pm
- Topic: Poor image quality when exporting as PNG
Re: Poor image quality when exporting as PNG
Check this page for more details.
Sicne you're creating the diagrams in Inkscape, it would be easiest and most productive if you'd export those as png's on 300dpi and than scale it down to the desired size, in mm's, in Gimp.
- Tue Oct 22, 2019 5:18 am
- Forum: Personal discussions
- Topic: i couldn't take it anymore
Re: i couldn't take it anymore
In times when the microwave or dishwasher has to update fonts, you`re complaining about the beta. And just as if that is not enough, you also could not keep it to your self but had to start a thread, about you... right. Do you do the same when you're off to the toilet as well? Do you find it to be i...
- Fri Oct 18, 2019 8:22 am
- Topic: How do I cut off the edge of a blurred object?
Re: How do I cut off the edge of a blurred object?
How comes Clipping does not work? Are all of these shapes on the same layer? If so, clipping should be the easiest and most efficient approach. Duplicate the rectangle (or desired final shape), place it above the group of all the other shapes and Clip or Mask it. Though, bear in mind that neither cl...
- Tue Oct 15, 2019 3:46 am
- Forum: Tricks & Tutorials
- Topic: texts on circle
Re: texts on circle
Have you seen these pages?
- Fri Sep 27, 2019 7:54 am
- Topic: PRINT ISSUES
Re: PRINT ISSUES
Glad to hear and you`re welcome!
- Fri Sep 27, 2019 12:15 am
Re: PRINT ISSUES
If you used Document Properties to define the page size (Ctrl+Shift+D) the just simply click on the Page tab (at the top of the Export dialog) and that`s what would be exported.
- Thu Sep 26, 2019 10:56 pm
- Topic: (Inkscape 0.92.4) Why don't my downloaded fonts show?
Re: (Inkscape 0.92.4) Why don't my downloaded fonts show?
The font works properly in Inkscape 48.5 and in other sw`s but does not work in 1.0. There was a change, due to recent Windows 10 updates, where folder path to the installed fonts has been changed (C\Users\... now, which previously was C\Windows\Fonts). Check this one first. The other thing which I ...
- Wed Sep 25, 2019 12:53 am
- Forum: General Discussions
- Topic: GRADIENT BANDING pdf/x1a printing issues
Re: GRADIENT BANDING pdf/x1a printing issues
Before you go short with your patience, do yourself a favour... Make one image with and one without that whitish overlay. After a while, take a break, and then have them both on screen. Now, ask yourself again: Does the one with it look that much better? (this is from my experience and "with it...
- Tue Sep 24, 2019 9:26 am
- Topic: Edit fill not working
Re: Edit fill not working
^ The way you`ve composed this shot is an absolute gem of avantgarde x]
- Tue Sep 24, 2019 1:41 am
You are welcome, and if I could be of any more help I`d advise moving away from jpg, jpeg and rgb of any kind at any cost while you`re trying to make this one look right on paper. Also, if you`re considering DTP (Desktop Publishing) - use either of those 2 terms for web search and - Good luck! \o/ p...
- Mon Sep 23, 2019 11:14 pm
"Q: Can I use RGB for print? A: Printed products like t-shirts, mugs, and canvas don't emit, but only reflect light. Therefore it is not possible to use the same additive RGB color system for printing. Almost every printer in the world prints uses the CMYK system – even your home or office colo...
- Mon Sep 23, 2019 6:43 am
Colour banding, a general, happens even with some plain colours since that particular tone can not be produced as desired, on paper, in the desired conditions, materials, machines... To be clear, cmyk colours are meant for printing and having recommended tones of colour is not by chance but to (most...
- Mon Sep 23, 2019 2:56 am
Hi! Welcome to the forum. Inkscape is a great vector tool but is somewhat estranged to printing. I`d warmly advise, especially if your interventions are as minor as you described them, to complete the preparation for print in either Acrobat or some other from Adobe palette (since you`ve mentioned th...
- Fri Sep 20, 2019 4:56 am
Obviously, we have just interrupted your inner dialogue.
Sorry about that :[
Sorry about that :[
- Fri Sep 20, 2019 4:22 am
Glad to hear you`ve sorted things out but - How comes your status bar (bottom of the screenshot, next to Layer 1) is empty, even with the object selected?
p.s.
Have you tried Ctrl+Shift+F for custom colours?
p.s.
- Fri Sep 20, 2019 12:14 am
- Forum: News, Events & Developments
- Topic: Inkscape 1.0
- Wed Sep 18, 2019 4:20 am
- Topic: how to get Trace Bitmap to save
Re: how to get Trace Bitmap to save
And what do you have on the screen (in the file) when you close Trace Bitmap window?
* try to include the status bar (bottom of IS window) in the next upload
- Tue Sep 17, 2019 11:06 pm
- Topic: Trim using Inkscape
Re: Trim using Inkscape
I hope you`re a good looking guy/gal ,)
- Tue Sep 17, 2019 11:05 pm
- Tue Sep 17, 2019 9:29 pm
can I trim the 3 lines with that circle ? I tried but I couldn't make it work. I thought the question was simple. Your quoting is equally confusing as your example, and here`s why... https://i.imgur.com/jam52pO.gif Thought, the answer along with a few alternatives (among which is the one displayed ...
- Tue Sep 17, 2019 5:50 pm
I had an idea on how`s the radio made but apparently Tesla has already tought it out.
Now, here`s a good read for you /
- Tue Sep 17, 2019 3:22 am
Perhaps you should check the Elipse tool further.
The toolbar changes for each tool and provides options. Have you tried that?
- Tue Sep 17, 2019 2:37 am
As those guides indicate, the whole image is made out of circles, where only a portion of the curve is used/displayed.
Check the Elipse tool.
- Sun Sep 15, 2019 8:21 pm
Try AMP Font Viewer - there`s a tab for installed and not installed fonts. Don`t open IS yet, go for the later tab in AMP, go to the desired folder and choose one of the options from the bottom of the screen (View all, View only not installed...). Once the chosen preview opens, fonts should be avail...
