Search found 122 matches
- Sun Oct 05, 2008 7:39 am
- Forum: Work in progress
- Topic: Wooden icon theme prototype
Re: Wooden icon theme prototype
@ioonquawl Thanks, yes you're correct about the arrow, now that you mention it, it's obvious! I actually forgot to change the perspective of the logo until after I had finished drawing it (the bottom has to be kind of stretched so that it looks correct) and so I didn't really make it as well as I co...
- Fri Oct 03, 2008 2:50 am
nils, I hope you're wrong but I take your warning into consideration :) Here is the (first draft of the) first icon! Inkscape seems to have exported the smallest icon badly, just ignore the white line at the top for now. Be brutal in your criticism... http://farm3.static.flickr.com/2107/2907825176_2...
- Fri Oct 03, 2008 2:44 am
- Forum: Inkscape Resources
- Topic: A little textured collection
Re: A little textured collection
Great work, I had no idea you could make such complex stuff with the filters. I /really/ need to learn about them!
Note to all: don't view this in firefox, you won't see the filter effects. Download it and view it in Inkscape
- Fri Oct 03, 2008 2:40 am
- Topic: Torn out page of paper.
Re: Torn out page of paper.
Thanks! Kind words indeed
- Thu Oct 02, 2008 9:59 pm
- Topic: Some gel effects
Re: Some gel effects
These a really amazing! Any chance of you making a tutorial to teach about filter effects?
- Thu Oct 02, 2008 11:40 am
Here is simplified version with example mime types...
- Wed Oct 01, 2008 11:31 pm
Thanks, yeah the ripping took ages manually tweaking ~30 cut-in circles with the node tool The texture is much more subtle than I expected, you're right. I have decided not to use texture at all unless I can work out a better way of using textures that aren't bitmaps than tracing them (most textures...
- Wed Oct 01, 2008 11:29 pm
- Topic: Inkscape logo colour explosion
Re: Inkscape logo colour explosion
Thanks guys
Maybe I will submit it!
- Tue Sep 30, 2008 9:50 am
- Tue Sep 30, 2008 3:11 am
- Topic: Desert Scene 2
Re: Desert Scene 2
Looks great
- Mon Sep 29, 2008 8:04 pm
Thanks! I'm glad you guys like it! It's a technically very easy piece, I just got my wacom tablet out and started scribbling because I was frustrated at some web development I was doing!
- Sun Sep 28, 2008 2:49 am
Here is the second prototype! Keep those comments and suggestions coming in, they're very useful to me! I've spent lots of time on this so I'd like to perfect it. Notes: [*] I've used a dummy logo this time, the rectangle would be the actual logo in the real thing. (the logo wouldn't be inside a rec...
- Sat Sep 27, 2008 12:00 pm
Just playing around with the ink tool when I should have been in bed.
Bigger Version
I challenge you to remix it and see what happens!
.Bigger Version
- Fri Sep 26, 2008 1:12 am
- Topic: The Attack of Mutant Fruits from Outer Space
Re: The Attack of Mutant Fruits from Outer Space
Looks great, and nothing wrong with using plenty of blur!
Keep it up!
Keep it up!
- Sun Sep 21, 2008 9:45 pm
- Forum: Tricks & Tutorials
- Topic: Thanks to HeathenX
Thanks to HeathenX
Just watched HeathenX's latest screencast on creating stitching effects and it's fantastic, so thanks for that and thanks for the great link to http://www.cgtextures.com/ (free textures)
http://screencasters.heathenx.org/wp-co ... ep071.html
- Fri Sep 19, 2008 6:51 pm
Wow, that's some excellent feedback Ioonquawl, thanks! You're absolutely right about the shadows. Unfortunately I'm not fantastic at getting perspective & lighting right so your tips are invaluable to me. Once I finish a current client project I'll modify the shadows and try to reflect what you'...
- Fri Sep 19, 2008 3:48 am
The problem about making the text bigger is that there has to be enough space for file extensions like .XHTML - that's the largest I could make the text and still fit it in whilst keeping consistency.
- Thu Sep 18, 2008 10:30 pm
Oh I see, so the problem only affects the smaller sizes - or do you think it also affects the larger sizes too? I didn't actually edit any of the smaller icons, I just scaled by 50% each time. I intend to make the 16x16px icon just say PDF (no pdf icon) and the text on the 32x32px icon larger, I jus...
- Thu Sep 18, 2008 9:54 pm
Thanks for the comments, I appreciate it!
Could you explain more about the difficulty in distinguishing them? I don't understand what you mean - I'm very open to suggestions for improvement.
I do think it would be a shame to take the realism away though.
- Thu Sep 18, 2008 1:42 pm
Hi all, I sat down at 10pm, in the mood to draw something using wood. It's just gone 4am now and I have no idea where the time went! I had a few crashes (and discovered a bug) but I got there in the end... Here's a prototype for an icon theme I'm making: http://farm4.static.flickr.com/3035/286628609...
- Tue Sep 16, 2008 5:38 pm
- Topic: Inkscape over command line (problem using verbs)
Re: Inkscape over command line (problem using verbs)
I'm not sure if the verbs wait to finish or not, but have you tried manually looking inside the troublesome svgs? Perhaps they have layers that are locked or something?
- Sun Sep 14, 2008 3:13 am
- Topic: How to compile the absolute latest unstable version in Linux
- Fri Sep 12, 2008 7:14 pm
- Topic: Simple ink wash effect using trace and mask in 0.45
Re: Simple ink wash effect using trace and mask in 0.45
Nice effect, could be useful for "grunge" style web design.
- Fri Sep 12, 2008 7:11 pm
- Topic: creative cloning
Re: creative cloning
That's a brilliant idea, well done! Thanks!
- Thu Sep 11, 2008 5:00 am
- Topic: Get gaps when you use patterns? Here's a work-around.
Firstly, if anyone can work out how to fix this properly please enlighten me! This is hands down the most annoying bug for me in Inkscape (and I have no idea how to fix the codebase) If you use patterns you will have come across the gaps that appear as horizontal or vertical lines sometimes. You mi...
