Search found 96 matches
- Sat Aug 18, 2018 2:27 pm
- Topic: How to set default png export path for all images exported as batch from one svg file
When you are clicking on multiple objects and selecting "Export png Image" > "Batch Export tickbox" > "Export" is there a way to choose the directory path for all images exported via batch export from that one svg file? Any ideas? Using latest Ubuntu linux with Inkscape...
- Wed Sep 13, 2017 6:26 pm
- Topic: Best way to reselect multiple objects
Re: Best way to reselect multiple objects
A nifty new feature. Looks good. Thanks. Oh but wait there is a small limitation of this new feature, one thing I wanted to do was that whenever I duplicate or copy an object I wanted it to automatically be part of the group, looks like this new method doesn't do that so if would have to be manually...
- Wed Sep 13, 2017 6:02 pm
I've been using the method where you put a keyword in the object properties then use the "Find/Replace" dialogue on the right but I discovered something strange that might be a bug. So if you choose some text in the design and you right click > Object properties then if you write anything ...
- Mon Sep 12, 2016 7:15 pm
- Forum: General Discussions
- Topic: Aligning to real measurements on a4 page
I am having a small issue and have a general question all about precise printing onto a page for the exact size. First I found that if I try to print directly from Inkscape the printout is misaligned and some is cut off from the left (is there a setting to fix this)? It works to export the file as p...
- Sat Mar 19, 2016 3:14 pm
- Topic: [solved] Can I batch export multiple objects (groups) all at once to png files?
Re: Can I batch export multiple objects (groups) all at once to png files?
Yes that works, I installed the plugin then noticed the batch export there and thought it was added with the plugin but if it's the default setup yeah it works great
- Fri Mar 18, 2016 11:31 pm
- Fri Mar 18, 2016 11:03 pm
If I have many objects on the page and I give each one an id field name is there any way to export them all at once each to a separate png file with the id field as filename. I can do it with the export dialog but only one at a time by selecting 'selection' then 'export'. Or is there some sort of sc...
- Tue Mar 08, 2016 12:37 am
- Topic: Is Inkscape ready to create svgs to replace images on websites?
Re: Is Inkscape ready to create svgs to replace images on websites?
Does the excellent browser support include raster images within the svg?
- Fri Mar 04, 2016 7:32 pm
Ok thanks, maybe I'll wait a bit longer. This is a slightly different thing but > Say for example you want to have an image that is replaced with another image and some text changes when a button is pressed (without reloading another page such as with php). I've been using a flash swf maker program ...
- Fri Mar 04, 2016 5:24 pm
Would it be too early to think of using Inkscape to create plain svgs (with text, vector graphic and raster image components) to replace images on websites (perhaps with fallbacks)? Would text in plain svg files be readable and used by search engines? Is it too early to have svg files as major parts...
- Sat Jan 30, 2016 7:14 pm
- Topic: Inkscape 'jpg export extension' not appearing in extensions menu
Re: Inkscape 'jpg export extension' not appearing in extensions menu
Thanks for the reply.
I'm using Inkscape 0.91 r13725
Should I downgrade to a previous version? It might mess up my files though, does anyone have it working in .91?
- Sat Jan 30, 2016 3:51 pm
I am trying to install the extension https://github.com/giacmir/Inkscape-JPEG-export-extension I have copied both files to the extensions folder but the extension is not appearing where it says it will in the extensions menu under export to jpg. C:\Program Files\Inkscape\share\extensions Am I doing ...
- Fri Apr 10, 2015 10:39 pm
- Topic: Export to jpg or convert pngs to jpg with another program?
Re: Export to jpg or convert pngs to jpg with another progra
I'm trying to go to the directory with cd dir
Then typing
mogrify -format jpg /*/*.png
But I get 'invalid argument' errors.
Then typing
- Fri Apr 10, 2015 7:14 pm
- Forum: SVG / XML Code
- Topic: Easiest way to render my svg with transparent background
I have an svg which I want to render as a png with a transparent background for an image fallback.
It's hand coded, when I open it in Inkscape it's all messed up, though it works in all browsers is there another way to render it with a transparent background to make a png?
- Fri Apr 10, 2015 6:53 pm
Thanks, how would I made this recursive?
I just have a bunch of pngs in different subdirs and I want to convert them all to jpg.
- Fri Apr 10, 2015 5:40 pm
I want to use inkscape to make images for a website but I save them in separate subfolders and change the images often. I can only export to png which is no good for the web, I can't use imagemagick to convert them all to jpg at once because they are saved in different subfolders. I did try one inks...
- Sat Mar 21, 2015 3:36 pm
- Forum: Inkscape & the Web
- Topic: Where to buy/get fonts without DRM/pageview hassles?
Re: Where to buy/get fonts without DRM/pageview hassles?
Yes thanks, that's what I'm looking at now. Yes there are a lot of good free ones.
Yes, all the drm and licensing has really put me off the whole idea of buying fonts, apparently at one stage there was even a pay per glyph viewed font licensing system.
- Wed Mar 18, 2015 4:45 pm
- Topic: SVG <image, <rect anchor?
Re: SVG <image, <rect anchor?
Hello,
Yes I have read tutorials and couldn't find anything.
Although this answer seems to confirm that there isn't anything unfortunately.
http://stackoverflow.com/questions/1972 ... -attribute
- Wed Mar 18, 2015 2:05 pm
Is there any way to anchor images and rects by the centre, as you can with text?
ie. text-anchor:middle;
- Sat Mar 14, 2015 7:23 pm
- Topic: How to limit svg text width in all browsers
Re: How to limit svg text width in all browsers
Nevermind, I worked out an acceptable solution to this.
I was using <text> with <tspan>'s including spaces.
When I just used two <text>'s without <tspans> it works well enough with different fonts to be good enough.
- Sat Mar 14, 2015 7:17 pm
I have a conundrum which might derail my entire svg project :( I have spent a few days redesigning my header completely in svg code. I have text overlaying a rectangle (the rectangle is a certain width). But how can I get the text to be the same width in all browsers and all fonts? I tried using the...
- Thu Mar 12, 2015 3:37 pm
- Topic: SVG Is there a relative position?
Re: SVG Is there a relative position?
I'm reading a much more in depth svg tutorial.
It seems svg nesting is the solution.
- Thu Mar 12, 2015 3:34 pm
- Topic: Some properties in stylesheet/inline stlye form don't work?
Re: Some properties in stylesheet/inline stlye form don't wo
Ok thanks, that is a much more in depth tutorial.
I have already found a solution to another issue in chapter six.
I had read another tutorial which didn't cover many of these things.
- Thu Mar 12, 2015 8:49 am
Thanks for the replies. I couldn't find anything else that was quicker so I used php using a variable for the main position then adding + number for the offset for individual elements. Slightly time consuming to write the first time but worth it for the ease of moving all the objects at once. Actual...
- Wed Mar 11, 2015 3:34 pm
