Thanks polygon!
And? Does it has anything to do with the dpi's ? What happened? Why does it comes out in different scale?
Search found 20 matches
- Wed Aug 09, 2017 5:08 am
- Topic: inkscape to blender.
- Tue Aug 08, 2017 10:34 pm
Re: inkscape to blender.
Here s the svg
Thanks in advance
Thanks in advance
- Tue Aug 08, 2017 3:14 am
Hello..when I Export an SVG. file into blender, the dimensions of the object are at approx 28% of the original. and the Position of the zero point. (X=0,Y=O)/ is at totally different place. Anybody can help me to unser stand what happened???
- Tue Aug 08, 2017 3:08 am
- Topic: path/image problem
Re: path/image problem
Thanks..i work in Windows but I never use shortcuts..did it by clicking the icons...
- Mon Aug 07, 2017 7:23 pm
path/image problem
hello there
something weird happened this morning ...
when i copy a path, and paste it into a new file it became an image....
anyone an idea what went wrong??
how to cure it?
how to cure it?
- Wed Oct 21, 2015 9:39 pm
- Topic: bezier envelope
Re: bezier envelope
Problem solved !
In my OS (C:) i ve got program files and program files (x86)
installed it at first one and everything works fine now...
- Wed Oct 21, 2015 3:53 pm
bezier envelope
Screenshot (54).png Hello out there.. I ve just installed bezier envelope addons on my laptop... Opened inkscape but in extensions/midify path menu drop down the bezier envelope is not there/visible.. on my home pc it shows "bezier envelope" here it only shows envelope but function is dif...
- Mon Jul 27, 2015 8:35 pm
- Topic: symmetry issue
Re: symmetry issue
yep .. you re right
thanks a bunch mister
what a wonderful program,isn t it?
have a nice day and thank you again
- Mon Jul 27, 2015 8:12 pm
Re: symmetry issue
thanks that was very informative, in fact I almost never pay attention to status bar but I really should now by adding a couple of stars, rectangle and a circle their "mirrors" came up at the right side of the canvas.....so I start to think I activated a mirror feature that i dont know abo...
- Mon Jul 27, 2015 7:19 pm
symmetry issue
hello world i downloaded an svg file somewhere and while playing around with I found out that there were kind of "linked groups" when I manipulated one node, the opposite node moved to. I am not so new to inkscape but this one confused me a bit, don t know how this achieved.. I would appre...
- Thu Jan 22, 2015 3:58 am
- Forum: General Discussions
- Topic: invisible layer????
Re: invisible layer????
thank you soooo much mister
I don t have any clue in the world how the stuff in red got in there
the outline tip is just great
thanks again ..
thanks again ..
- Thu Jan 22, 2015 2:17 am
yes that was the Problem .... stuff grouped and on top of eachother.. as well fills and strokes missing some how.... but no idea how that happened... :roll: thanks a lot.. that helped here s svg just with Problem Areas.. how can you see this more easy when such things occur?? i only saw it in other ...
- Wed Jan 21, 2015 9:41 pm
invisible layer????
hello out there seems like I have an invisible layer with partially same (slightly moved) geometry they are all on same layer but only visible in nodes mode... how did that get there? why is it not visible in normal mode?? how can I get rid of it easily without individually selecting the nodes?? tha...
- Wed Oct 15, 2014 8:48 pm
- Topic: extend node selection
Re: extend node selection
well. now i can spend extra time in the Couch with the Lady instead of sitting behind my Computer
thanks again
thanks again
- Wed Oct 15, 2014 5:57 am
well thank you sooooooo much, that was veryyyy helpful... you helped saving my wedding
- Wed Oct 15, 2014 5:17 am
hello
how can I extend the selection of nodes ..I want to remove a whole bunch of nodes who are connected to eachother..... by starting with one...
tried ctrl+ but doesn t work...
i am doing it 2 by 2 but it takes eternity for removing all the desired ones...
thanks in advance
thanks in advance
- Tue Jun 24, 2014 3:02 am
- Topic: double nodes
Re: double nodes
ok thanks a lot all of you
Problem solved
had a lot of same objects on top of eachother
where I should have had 700 nodes I had 7000
still don t know how that did happen
Problem solved
- Sun Jun 22, 2014 5:25 pm
double nodes
Hello out there, I have 2 small Problems... 1. on a project , probably by copying, I have lots of nodes stacked on top of eachother,( Grey nodes without outlines) is there a way to remove those superfluous and keep only one??? at some places I got 3 on top eachother, other places 6 or more and I wan...
- Tue Nov 12, 2013 10:07 pm
- Topic: Engraving
Re: Engraving
thanks for the help and the links...
the drawing is not the issue, that works ok, it s more the behaviour of the milling head, g code extensions.. following the path i am looking for, but he link will help me further..
thanks a bunch and sorry for the late reply, been fishing;-)
- Wed Jul 10, 2013 8:51 pm
- Topic: Engraving
Engraving
Hello I am using Inkscape for cnc engraving Projects.. using g code Tools.. using a path to g code to follow lines... so far all ok... Now... I want to go further and do the engraving with variable Z axes determining the line width... like tapered lines, bezier curves with rectangle in or out lines,...
