Search found 6 matches
- Tue Apr 07, 2009 8:34 am
- Topic: color questions
Re: color questions
ok, so I now know how to know what color model I'm using, but still don't know if I can use spot colors...
- Sat Mar 28, 2009 8:51 am
color questions
how do I know what color model I'm using in inkscape, like RGB and CMYK. also, does it support spot colors?
- Tue Mar 03, 2009 11:31 am
- Topic: How to get nicely rounded shapes and lines?!
Re: How to get nicely rounded shapes and lines?!
you could cut part of the circles by going to path->object to path-> and then use :tool_node: to add nodes around where you want to cut off(select them both) and then near the top with the tool options click the button that is 5 away from the left which says "split path between two non endpoint...
- Mon Mar 02, 2009 10:40 pm
- Topic: making semi realistic windows
Re: making semi realistic windows
thanks for the help
- Mon Mar 02, 2009 9:19 am
well, I wasn't thinking to put any relflections on them, just some highlights. however, a tutorial or something on a basic way to make a window would be great and then I can expand on that myself.
- Mon Mar 02, 2009 7:48 am
I was wondering how to make windows on buildings and such look a tidbit real and glossy. can anyone help?
thanks
thanks
