Search found 6 matches
- Mon Aug 03, 2009 11:29 pm
- Topic: how to make perfect round with node tool ?
Re: how to make perfect round with node tool ?
'path > reverse' works ! i do make closed paths of them. thanks again, your help is much appreciated. and if you don't mind if i borrow some more of you inkscape-wisdom, could you tell me if there is another (easier) way to set the first point of a path, besides going into the xml-editor and copy-pa...
- Mon Aug 03, 2009 10:01 pm
- Topic: A setting to round the numbers off.
Re: A setting to round the numbers off.
use a grid and snap to that while drawing.
that works for me.
that works for me.
- Mon Aug 03, 2009 9:07 pm
thanks a lot! the
-tool is pretty neat with the ctrl-key pressed
one additional question:
once i have my path closed is there a way to flip the other of the nodes from clockwise to counterclockwise ?
-tool is pretty neat with the ctrl-key pressed one additional question:
- Mon Aug 03, 2009 8:23 am
- Forum: Tricks & Tutorials
- Topic: Development builds: Easy to install and sexy new features.
Re: Development builds: Easy to install and sexy new features.
is this windows only ?
i'm on a mac. but would love to use spiro.
EDIT: found it, mac snapshots: http://inkscape.modevia.com/macosx-snap/?C=M;O=A
- Mon Aug 03, 2009 8:22 am
thanks for the reply, and spiro looks real sweet.
but
i'm on a mac..
i found this though.. : http://www.whizkidtech.redprince.net/bezier/circle/
it helps a little.
but
it helps a little.
- Mon Aug 03, 2009 4:13 am
hi, i'm in need of some help. after googling and not finding it i decided to ask here. i draw my path with the pen tool and then i use the node tool to make certain parts round. all my curves need to be perfect round. like parts of a circle. i'm using inkscape to design levels for a game so i need t...
