Search found 7 matches
- Mon Aug 26, 2019 4:44 am
- Topic: Uploading videos to Inkscape Forum
Re: Uploading videos to Inkscape Forum
I was wondering if anyone has solved this issue without having to create an account with a third party. I'm trying to upload another screen recording for yet another question I have involving Inkscape but still get the same error message.
- Sun Aug 25, 2019 2:12 pm
- Topic: Nodes will not "snap" together
I am recreating an image mostly using the bezier tool and the fill tool. To start I took an already existing photograph and used the bezier tool to create an outline. I then filled this selection and made it slightly opaque so that I could see through to the image behind it. Using the same technique...
- Mon Jul 22, 2019 2:11 pm
These online sharing sites are not converting or compressing anything to my knowledge. So I should be able to convert the video to which ever file extension is supported by the software used to render media in this forum. I created a Dropbox and I'm having the same issue. It seems like there is some...
- Mon Jul 22, 2019 1:12 pm
Thanks tylerdurden. Do you know why it works that way. I'm looking for another option, because I don't use either of those services.
- Mon Jul 22, 2019 8:38 am
I would like to upload a video to a topic that I started about another issue on this forum but I keep getting this error message. I have tried .wmv and .mp4 with the same result.
- Sun Jul 21, 2019 8:59 am
- Topic: Using the Difference command
I have placed multiple ellipses on top of a leaf design with the intent of them being cut out from the leaf so that it looks like the leaf has holes in it. I selected everything and then used the Difference command under the Path window and achieved the look that I was going for, except it was only ...
- Sat Jul 20, 2019 6:16 am
- Topic: Erasing parts of grouped objects
I have been working on this leaf design on a white background, to find out that instead of erasing I must have been drawing with a white stroke. Once I believed the design to be finished I grouped all of the components and moved it on top of a preexisting object and saw all of the white lines by the...
