Search found 4 matches
- Fri Sep 16, 2016 7:20 am
- Topic: [solved] Path disappearing after using outset
Re: Path disappearing after using outset
Hey, everyone. I figured it out. It was clipped. I missed that on the bottom of the screen. When I noticed it, I released the clip and now I can modify as needed!
- Fri Sep 16, 2016 5:04 am
- Forum: Inkscape Ideas
- Topic: Design Change: Joining Nodes
Re: Design Change: Joining Nodes
Unfortunately there's no way to join two nodes in the way you want - the SVG format simply doesn't allow for it. You can, however, use snapping to get your two nodes to be co-located. If you subsequently try to move one, the other won't go with it, but you may be able to get round that by "rub...
- Fri Sep 16, 2016 5:02 am
Hello all. I am designing something using puzzle pieces. The pieces don't fit exactly, so I need to make them larger so that they will fit securely together. I've tried using the Outset, Dynamic Offset, and the Linked offset. However, as the image grows, the path disappears and I can't figure out wh...
- Fri Sep 09, 2016 12:13 am
Hello. I am running into this issue as well. In the thread, I noticed that it was mentioned that the two nodes to be joined have to be end nodes. I need to join an end node and a middle node. I am trying to form an E. Is there not a way around that? I can't use text because I do not have a font that...
