Search found 11 matches
- Sat Dec 05, 2009 11:17 pm
- Forum: General Discussions
- Topic: cmyk and inkscape
Re: cmyk and inkscape
Of course! I promised not to use Illustrator never more after I discover Inkscape 4.7 this two last weeks and... after only some days I'm using it again :(, cause I have to make some printable work that I must send to printer's... So, well, although this seems like a very common issue, I only wanted...
- Wed Dec 02, 2009 7:28 am
- Topic: Shapes with "Unset" Fills results in a totally Black Shape.
Re: Shapes with "Unset" Fills results in a totally Black Shape.
...ARGH! I didn't want to sound too much rough with this kind of professionals cause they are the thing I more admire (and envy, OTOH :roll:) in this world! So sorry if I expressed myself in an inadequate mode :oops: Well, turning to the issue... yeah! Although I still have thought in many similar w...
- Wed Dec 02, 2009 6:09 am
Wouldn't it be hard to select the object if it were invisible? Not with "Outline Dysplay Mode" (Ctrl+5), that I used to use all the time that I want to select something precisely, or even it could still been "selectable" by dragging a selection box. In fact, you can actually sel...
- Wed Dec 02, 2009 4:01 am
Ops! :( It seems that if I drag the "object" it into the 'svg:defs' I can't select/modify it anymore so... I suppose I should be dragging it "in & out" every time I want to make a modification to the original clone or... well, I suppose too that I could wait to put it there a...
- Wed Dec 02, 2009 3:29 am
...Ey! I didn't imagine that I should start to use that kind of XML features so soon!
Jeje... Of course I'm going to try it right now
, thank you very much again!
- Wed Dec 02, 2009 2:47 am
Ahhh... a pity, but good to know it! So thank you very much :) Then... how do yo think that original black object could be avoided in my art work? Cause I see how sometimes it could be hidden below his clones, but it coudn't be possible in several situations where holes or transparency be involved, ...
- Wed Dec 02, 2009 2:26 am
- Topic: How do I get the "Freehand Shape" extension for 0.47pre3 ?
Re: How do I get the "Freehand Shape" extension for 0.47pre3 ?
Oh, yeah, that operators... Well thanks for the imput, but... unfortunately they are simply not the same :(, I mean, at least in the above workaround, the shapes remains linked and... editable! :o and that's why I liked it so much... But in this case, using that old boolean operators, means thay I'm...
- Wed Dec 02, 2009 1:50 am
Hmmm... sorry in advance! But I still wonder if it'll be a normal behaviour that an "Unset" fill makes my shape filled with an opaque black and, as I don't know who more could I ask, I must insist :P ...Anyway, don't you think that if I want a black fill I'd fill it with a normal black col...
- Wed Dec 02, 2009 1:16 am
Good to know, so... THANKS!
Now the perfection would be to find a workaround to "emulate" that INCREDIBLE "Boolop" path effect
- Mon Nov 30, 2009 7:10 pm
D'oh! It was mine... I only didn't know you can reply even when you was unlogged...The worse part is I'm not able to edit now and there are several "typing" errors on it, so... SORRY! I'd take it into account from now on...
- Mon Nov 30, 2009 11:21 am
Hi, first of all... I'm enjoining a lot with this incredible piece software! Now... When I apply "Unset" to a fill of a original path of a series of Clones (so I can than apply different fills for each of his clones), I get that the original path is filled with a totally black fill! Instea...
