Using exact same Inkscape version but on High Sierra.
Changing colors, editing nodes, not noticing any problems at all.
Seems like something with Mojave?
Search found 83 matches
- Sat Sep 21, 2019 12:01 am
- Topic: 3D box disappears after changes
- Fri Jul 05, 2019 12:17 am
- Topic: How to uninstall Inskape 0.92 on Mac?
Re: How to uninstall Inskape 0.92 on Mac?
So what happened with the install? Any errors listed? Can’t find it? Do you have the ‘Mac Ports-Guide’ Docs ? https://guide.macports.org Since you’ve used Macports to install Inkscape you are familiar with the Terminal command line and how to get there. Im not a Macports guru, but there is one thing...
- Wed Jan 23, 2019 6:42 am
- Forum: General Discussions
- Topic: Inkscape Fails to Launch on Mac OSX 10.10.4
Re: Inkscape Fails to Launch on Mac OSX 10.10.4
Good to hear this.
- Sat Nov 03, 2018 11:54 pm
- Forum: Off topic
- Topic: Anyone tried "Pencil"?
- Wed Oct 03, 2018 11:10 pm
- Topic: Difference's with PC verses Mac High Seirra
Re: Difference's with PC verses Mac High Seirra
The following would seem to be of some help for you.
https://shortcutworld.com/Inkscape/mac/ ... _Shortcuts
- Fri Jun 15, 2018 6:36 am
- Topic: Lock file to prevent simultaneous edits
Re: Lock file to prevent simultaneous edits
Have you considered just locking the file at the system level ? This way, only you can unlock it, but they will only be able to save it as a copy or rename it incrementally. In OSX (Mac user here) just find the file in your Documents folder and do a ‘get-info’ (or windows equivalent) and just check ...
- Sun Feb 18, 2018 12:01 am
- Forum: Personal discussions
- Topic: Introduction
Re: Introduction
Wow, thanks for that correction.
Senior moment here, I guess, sorry.
- Sat Feb 17, 2018 11:45 am
Re: Introduction
Thank You for your visit. I recalled your name immediately, as I remembered the day so well, about a year ago, when somebody finally made a nice working build of Inkscape 0.92 for Mac available , and it was you, right? So, a big thanks from a Mac user who appreciates your efforts, for sure.. I’ll be...
- Thu Feb 01, 2018 10:29 am
- Topic: Cargo aircraft
Re: Cargo aircraft
Vey nice there.
- Fri Sep 08, 2017 7:00 am
- Topic: Does Inkscape have ways to create these sorts of sprites easier?
Re: Does Inkscape have ways to create these sorts of sprites easier?
Here's a couple old links that may become some starting points...
http://2dgameartforprogrammers.blogspot ... ients.html
http://speckyboy.com/2009/04/28/35-tuto ... -inkscape/
- Fri Sep 08, 2017 6:11 am
- Forum: SVG / XML Code
- Topic: How does the Interaction menu work (with javascript)?
Re: How does the Interaction menu work (with javascript)?
Here’s a link to some tutorial examples that may provide some help for you.
Inkscape & Snap.svg | GoInkscape!
http://goinkscape.com/category/inkscape ... -snap-svg/
- Sun Jul 16, 2017 1:08 am
@JonasCollet,
So... just to keep this thread useful to any other OSX users,
What MacOS and what Quartz version are you running there with the 0.92 version provided by Tim Sheridan ?
- Fri Jul 14, 2017 9:12 am
In stead of double clicking to open Inkscape, try a right click and then choose open (there's a difference). If it's the first time you will be opening it, you must be patient while it inits all the fonts, etc.... It could be a full minute or so... just wait for it, that is, unless it just still bou...
- Mon Apr 10, 2017 10:48 pm
- Topic: Inkscape Animation Project
Re: Inkscape Animation Project
Interesting, so I guess you've created an extension that animates the frames?
Then save as a .gif, like in Gimp ?
- Tue Apr 04, 2017 2:43 am
- Topic: My introduction
Re: My introduction
You must have the wrong link but it displays nicely here.
The Mackbook and iPhone seem quite obvious here.
- Sun Mar 05, 2017 2:03 am
- Forum: News, Events & Developments
- Topic: unofficial 0.92.1 DMG test version (for Macs)
Re: unofficial 0.92.1 DMG test version (for Macs)
Perhaps I could have posted this sooner but …. I D’Loaded the new 0.92.1 version of Inkscape for Mac, thanks to Tim Sheridan, and it opens nicely and works quite well here. 0.92.1 sits right there next to 0.91 in my /applications folder however, 91 & 92 share the same preference files. At least,...
- Sun Feb 19, 2017 2:56 am
Thanks, ~suv.
On closer inspection, I now see the numbering convention used.
Of course, 'Pre' would have been the very first.
I'll try the latest one instead.
Also, I noted the path/thread to where Tim can be reached.
Cool
Cool
- Sun Feb 19, 2017 12:42 am
So glad to see some progress for us Mac users. THANK YOU BRYNN ! , for your kindly concern, and your help in providing an update path for us Mac users. (The Link seems to work just fine, as it stands right now) Of course, the real thanks go to Tim Sheridan for the nice test build of 0.92.1 to play w...
- Wed Jan 18, 2017 3:50 am
- Topic: Newbie to Inkscape and installing on a Mac
Re: Newbie to Inkscape and installing on a Mac
The link for Macports is simply’ Macports.org ‘ and everything that is needed to get started, can be found there. At Macports.org there actually are existing projects for Inkscape 0.48, 0.91, and 0.92pre-4, but they are only in the ’source’ format, so each user would have to build the application fo...
- Tue Jan 17, 2017 3:13 am
I'll be watching this thread closely for any responses as I may give macports and inkscape a try very soon. I still use 0.91 on El Capitan (10.11.6) but usually, sooner or later, someone does a Mac compile and we Mac users will get to enjoy 0.92, hopefully. Ideally, I would think that just typing 'i...
- Sun Feb 14, 2016 12:07 am
- Topic: OS X version 10.11.3 ok with Inkscape?
Re: OS X version 10.11.3 ok with Inkscape?
0.91 Running fine here on 10.11.3
- Wed Oct 14, 2015 11:57 pm
- Topic: Lighthouse and Sea
Re: Lighthouse and Sea
So, this is an Inkscape creation ?
How much of it is "based on a photograph" ?
That's amazing. isn't it ?
It looks like 100% photo?
- Wed Oct 14, 2015 11:50 pm
- Forum: Registration issues and website problems
- Topic: Looks good but ?
Re: Looks good but ?
Ah-Ha, there they are, kinda hiding up there !!!
Thanks guy
Thanks guy
- Wed Oct 14, 2015 11:09 pm
Looks good but ?
The look of the new site page(s) is quite nice, I think but, ....
I miss the "view new posts" button, which I would often use when I log in.
Can/will we be getting that back ?
- Mon Jul 27, 2015 8:55 am
- Topic: Change Fonts used in document
Re: Change Fonts used in document
Ahh Yes, I knew it was there.. somewhere… As it turns out, somehow, I ended up being in Inkscape 48.x and did not realize it !!! I am feeling quite embarrassed now, actually, as I recall how nice it was to have the new 0.91 version. I somehow had the wrong alias version in the Doc ? Thanks ~suv for ...
