Search found 55 matches
- Mon Sep 11, 2017 8:36 pm
- Forum: Inkscape Resources
- Topic: Screen recorders, capture, etc.
Re: Screen recorders, capture, etc.
Interesting the differing approaches Never had much problem with screencaptures in linux, probably because over the years I have always used KDE. This in Kubuntu 16.04. KDE uses 'activities' as well as 'desktops' This my 'activity' setup for screencapture, only inside the box is recorded using ffmpe...
- Mon Nov 07, 2016 12:18 am
- Forum: Off topic
- Topic: anyone tried slimjet or maxthon browser?
Re: anyone tried slimjet or maxthon browser?
Use slimjet all the time.
12.06.0 in this kubuntu machine and older 32 bit versions on a linux netbook and my 32 bit PCLOS desktop.
A little heavy on resources but very configurable.
adverts? what are they. screenshot: http://imgur.com/SLL0xnO
- Tue May 24, 2016 8:28 pm
- Topic: How to delete text below the image?
Re: How to delete text below the image?
Sometimes you need a crystal ball. In this case I think it is this:
http://i.imgur.com/mcepf6u.jpg
Select the text, hit the delete key.
- Thu Mar 31, 2016 7:23 pm
- Forum: General Discussions
- Topic: [solved] How to burn svg to CD
Re: How to burn svg to CD
It is just another data file.
What you use to burn to a CD depends on your OS and available burning application.
- Sun Nov 15, 2015 10:28 pm
- Topic: Halftone vs. Dithered Shading
Re: Halftone Shading
I might be missing something here but surely the point of traditional half-toning, as in reproducing grayscale images for printing, is the dots are on a regular grid and the dot size introduces the toning effect. A checker board pattern of different size is not strictly half-toning. A very coarse at...
- Fri Jun 05, 2015 9:43 pm
- Topic: linux installation
Re: linux installation
You should be using apt-get and need to update the package lists first
then
sudo apt-get updatethen
sudo apt-get install inkscape- Fri Mar 20, 2015 2:41 am
- Topic: Technicbold font
Re: Technicbold font
I can see the problem now, part of it was language, I thought the font as referenced did not show in ubuntu. It is part the difference in rendering engines between Windows and Linux, together with old font is (1996) and broken. The characters are on wrong codes. This might work, I rebuilt the font w...
- Wed Mar 18, 2015 8:16 pm
Ok I got the euro font mixed up. From your link: TechnicBold.ttf 78,368B Back to the original question of installing in linux. That font in my home folder ~/.fonts The font displayed in Inkscape and in Gimp. screenshot http://i.imgur.com/lER6TOw.jpg As far as I am concerned that is how the font looks.
- Tue Mar 17, 2015 11:50 pm
But in windows the font likes......Please see attachment. I think there is something wrong with the font, especially in linux. Regardless, the font looks very different from your windows example. Had another look at the download link. This time the site showed a preview character map. The ttf file ...
- Mon Mar 16, 2015 11:48 pm
Not ubuntu, this in PClinuxOS KDE. Inkscape 0.91 screenshots http://i.imgur.com/ntQ0ir7.jpg There is something a bit strange with the font, as seen on the download page with non-displaying charachters but.. Have you tried putting the font in your (hidden) home folder ~/.fonts. If you do not have one...
- Sat Nov 15, 2014 9:41 pm
- Topic: Need help making drawings into single line art 4 whiteboard
Re: Need help making drawings into single line art 4 whitebo
Tyler, tried what you suggested and it still comes out as multiple objects verse a single line. I found this out by selecting the 'edit paths nodes' and you could clearly see it is outlined verse a single line. It is because Inkscape does not do a centerline trace. You need to run a bitmap (prefera...
- Sat Nov 08, 2014 7:49 pm
- Topic: Colours and Inkscape
Re: Colours and Inkscape
I noted an online tracer mentioned in another thread on this board, and thought that I would try it to see the effects. I do not want to get too far off topic but that online tracer is based on autotrace Generally the Inkscape trace is more than adequate. Based sometime in the distant past on Potra...
- Fri Oct 31, 2014 7:55 pm
- Topic: Where is the SVG Template stored
Re: Where is the SVG Template stored
Even 'buntu follows the conventions.
Set up a page & save as default.svg to your home directory ~/.config/inkscape/templates
looks like this http://i.imgur.com/GxuhV9j.jpg
- Tue Sep 23, 2014 4:22 am
- Topic: seeking vector french curves for inkscape
Re: seeking vector french curves for inkscape
A larger image will certainly help, did this before that last post. This is more an exercise in bitmap tweaking than anything else. (all in Gimp) The gif is a bit small so too many jaggies on the outline. First convert from indexed to RGB. Normally scaling these is a waste of time but in this case, ...
- Mon Sep 22, 2014 8:52 pm
Maybe as a starter. From a gif to a bmp then vectorised using Autotrace (still works in linux) using the centrerline switch.
- Mon Sep 01, 2014 8:03 pm
- Topic: Make Layer Lock Icon clearer. (SOLVED)
Re: No luck yet!
There is no folder at .../Inkscape/share/icons/icons.svg on my PC on Kubuntu 14.04 Further research yeilded: /usr/share/inkscape/icons/ and icons.svg. But they are different from the ones in use by inkscape. Can anybody help me? This drove me potty yesterday. Using PClinuxOS KDE 32 bit & Inksca...
- Wed Jul 23, 2014 7:34 pm
- Topic: Help with squares and printing on both sides of paper
Re: Help with squares and printing on both sides of paper
@ woopydalan I don't understand how to use the tiled clones/align and distrubute panel/rows and columns option. How can I make one 15x15 mm square, then print a few of them in rows and columns and have them line up so I can print them on the back?.. I have a bit of sympathy for you, as with most gra...
- Mon Jul 21, 2014 5:38 pm
..The one you are posting doesn't look like all the squares are the same size. Also, they aren't lined up... That is because it is a copy of your graphic, which was flipped horizontally as previous posts. You spent a long time on it so why change anything. It would be better if you started from scr...
- Mon Jul 21, 2014 3:45 am
Do you realise you drew 7*13 squares over the original 8*14? Sorry, having one of those senior moments. By flipping the paper in the printer, you cannot guarantee they will mach exactly. However I did print the original off (Brother inkjet with not the greatest of paper feeds), both sides and they ...
- Sun Jul 20, 2014 11:08 pm
As the previous post it is a mess. This is the first 'square' (red) evenly distributed over the existing squares (gray) http://i.imgur.com/Olv6jt2.jpg Still possible to print the original however. Make a rectangle the same size as the paper. Set the size manually so the origin is 0,0 Shows here as y...
- Fri May 30, 2014 6:48 pm
- Topic: Problem exporting to PDF CMYK
Re: Problem exporting to PDF CMYK
I get the same here, using PClinuxOS 32 bit & 0.48.4 That error message and it generates a zero length PDF file. The alternative cmyk-tiff is a bit better. Still a couple of error messages and best to lose any transparency but it does work. Then of course you have to package that as a PDF, Do no...
- Wed Apr 09, 2014 2:53 am
- Topic: linux user (Antix)
Re: linux user (Antix)
Getting a bit off topic here but The way *nix packaging works with dependencies and files scattered about makes 'portable' not so easy. however there are some: http://sourceforge.net/projects/portable/files/ AFAIK these are all 32 bit and tend to be old-ish. There is an Inkscape there, never tried i...
- Tue Apr 08, 2014 9:39 pm
When I tried to download it and use it in Antix I took the option of saving to desktop. I do not understand that bit. Did you download a .deb package maybe or perhaps the source code as a 'tarball' something.tar.gz It should work if you install using synaptic, down in the preferences section I thin...
- Thu Mar 27, 2014 8:02 am
- Topic: Vectorize a map
Re: Vectorize a map
The problem with the image is that it is 1 bit (black and white) and indexed. You can improve it in Gimp for use in Inkscape by Change the mode to RGB (in the gimp image menu) Apply the erode filter (filter - generic menu) to shrink the white pixels. Since the gray is virtually a black/white 1 pix c...
- Sun Jun 23, 2013 10:09 pm
- Topic: DPI
Re: DPI
Just for info: Gimp opens an svg file as a raster image and there is an option to set the ppi to whatever value you want. There is also an option to import the paths at the same time but that is all that is imported, just a path, no fill, no stroke. It is probably back to being a page size issue wit...
