Search found 9 matches
- Sat Jul 20, 2013 8:41 pm
- Topic: Repeat action, shortcut sought
Re: Repeat action, shortcut sought
If you are looking for a dialog in Inkscape which lets you repeat in a single step a transform that consists of rotations, scales, and translations Inkscape does not have one... Have you tried the transform dialog, ctrl-shift-M which allows you to apply a transform to objects repeatedly? As Lazur p...
- Tue Jun 18, 2013 9:20 pm
Thanks for your answers, I will check them once I arrive home.
- Tue Jun 18, 2013 6:05 pm
I don't have any problem to adapt to slightly different workflows, the function I want it is just not there. I want to use transform and then repeat the same action BUT from where the last one landed the object. Let me explain it in detail, just in case there is actually a workaround I'm missing her...
- Tue Jun 18, 2013 8:35 am
- Forum: Off topic
- Topic: Earning a living using Inkscape
Re: Earning a living using Inkscape
I make a living out of graphics design and printing and as of that I have considered many times if I can do my job with open source programs. So far the only opensource program I believe is ready for prime time, is not graphic related and I talk about libre office. I do all my writing there and I be...
- Tue Jun 18, 2013 8:00 am
Hello, I just want to add my 2 cents here, a repeat tool is what I could love to see in inkscape as well. I use illustrator and it is done with ctrl+D or cmd+D (I work both in win/linux and osx) and it really helps with many designs. For example I made this http://www.behance.net/gallery/Patternity/...
- Sun Oct 30, 2011 9:05 am
- Forum: News, Events & Developments
- Topic: OS X-Native Inkscape coming?
Re: OS X-Native Inkscape coming?
hello sorry for reviving this old thread, just want to know if everything is going the same way with a native OSX inkscape version. The X is a real pain, especially the inability to use the command button with the shortcuts is killing my workflow. Thanks for your time and your work with inkscape :to...
- Thu Aug 26, 2010 6:25 am
- Topic: Import from open clipart library in windows?
Re: Import from open clipart library in windows?
oh thanks, I hope it is gone be fixed soon, it is so helpful
- Thu Aug 26, 2010 1:15 am
Hi I just can't see that menu in my inscape file menu. I use inkscape 0.47 in windows vista 64. In my macbook (osx 10.6.5 everything is fine).
Any idea what is going on?
- Thu Aug 26, 2010 1:10 am
- Forum: Inkscape Ideas
- Topic: Mac UI, COCOA Port
Re: Mac UI, COCOA Port
I'd like to weigh in on this. As a Mac user and artist with 20 years' experience, what I value in software tools is: Capability Stability Speed I expect a modern software application to have a helpful, easy-to-use interface. This is not a matter of eye candy, or looking cool. In my years of compute...
