Search found 5 matches
- Sat Mar 28, 2015 3:21 am
- Topic: [Solved] Objects don't snap when I draw them
Re: Objects don't snap when I draw them
That worked! Thank you so much!
- Fri Mar 27, 2015 6:24 am
I upgraded to v 0.91 and haven't had much time to play with it. One thing that I'm having trouble with is that when I draw an object, it doesn't snap to the gridlines like it used to. I'll draw the object and it just lets me draw it however. Then after, when I resize, it will happily snap to the gri...
- Fri Mar 27, 2015 6:18 am
- Topic: Saving my work in the PDF format
Re: Saving my work in the PDF format
Hi Caroline,
You could do print and select a PDF option (most computers have a PDF printer built in, or I love Bullzip or CutePDF), and do it that way. It might be a quick fix until one of the more knowledgeable people on here can better answer you question
- Thu Feb 12, 2015 3:12 pm
- Topic: Solved: Pattern fill is not consistent when resizing a shape
Re: Pattern fill is not consistent when resizing a shape -V
That worked! Thank you!! I was hoping it was something obvious like that.
- Thu Feb 12, 2015 2:40 pm
Hello! I have Inkscape on my home and work computer and when I use the pattern fill, they behave differently. On my home computer (v 0.48.5), when I have a pattern in a rectangle and shrink it in half, the pattern auto-adjusts to the new shape size: 1.png My work computer also had v 0.48.5 until tod...
