Search found 20 matches
- Sun Feb 08, 2009 12:50 am
- Forum: Inkscape & Cutters/Plotters
- Topic: Path to DXF questions
Re: Path to DXF questions
Hi What I have done so far is: exporting dxf in Inkscape through better dxf or R12 DXF, then I have opened the file in CadStd (also a free program), and there I have changed the linethickness and the colours of the lines, But I must wait till the lasercutter-company will let me know next week if the...
- Sat Feb 07, 2009 5:48 pm
Thank you for your help, but as I see in the text, that program works with eps files and not with dxf files..
- Sat Feb 07, 2009 4:53 am
Hi, I have tried that immediately, but I do not see a difference between the Better DXF output or R12 dxf output. The image is still in one colour and all the lines have the same thickness I am new to CAD-files. Has CAD-files normally no more then one colour ore one line-thickness? I need the file f...
- Sat Feb 07, 2009 1:49 am
I have now a better DXF file thank you, but unfortunately now still everything has the same colour and thickness..
it is not possible to keep the colours in the image?
- Sat Feb 07, 2009 1:35 am
I will try that immediately
- Fri Feb 06, 2009 6:25 pm
for some reason I couldn't install pstoedit properly. I have downloaded a PDF to DXF Converter 6.5 : http://fileforum.betanews.com/detail/PDF_to_DXF_Converter/1132582311/1 , I have saved the inkscape file as PDF and converted that to DXF in the program if I view that file a cad viewer all the lines ...
- Fri Feb 06, 2009 5:40 pm
I saw today an another topic about this problem, I have not tried it yet, but maybe this is the solution..
http://www.inkscapeforum.com/viewtopic.php?f=5&t=1533&p=7960&hilit=save+as+dxf#p7960
- Fri Feb 06, 2009 4:57 pm
I have the same problem.. I have made a drawing in Inkscape and I need to export it in .dxf so that a technical machine can use it..
I don't have a cad-program myself, but I have tried many cad-viewers and then nothing appears,
I hope that somebody can help us
- Thu Feb 05, 2009 7:02 pm
- Topic: Problems with printing items
Re: Problems with printing items
Hi Micro..
I have solved the problem. I remembered you first remark about the printer-driver. Although my printer is brightnew, I have downloaded an another driver from the official epson website. And now I can finally print items..
- Thu Feb 05, 2009 3:35 am
I have done what you have said, but unfortunately I still cannot print,
- Thu Feb 05, 2009 3:21 am
Ok, I will try,
Thank you..
Thank you..
- Wed Feb 04, 2009 6:54 pm
- Topic: Making from 2 paths 1 path
Re: Making from 2 paths 1 path
I worked when I first combined the both paths, and then used the join end nodes button,
- Wed Feb 04, 2009 6:38 pm
Windows XP
- Wed Feb 04, 2009 5:57 pm
Thank you for the help, I will try that today..
- Wed Feb 04, 2009 5:19 pm
The latest driver is installed. I have no problem with printing documents in every program. Only Inkscape has problems with printing files.
Is there a way to solve this problem
- Wed Feb 04, 2009 6:17 am
Hi, I am wondering what the best way is to combine paths, I want to make an symetrical image. I have made a path of half of the image, then I have copied the path and I have flipped it over. To make one path out of these two halve paths I have chosen for the ctr ++ command. But then a line appears i...
- Tue Feb 03, 2009 11:37 pm
I have problems with printing items in Inkscape. If I try to print an item, I receive the following message: In Spooler SubSystem App is een fout opgetreden en moet worden afgesloten. Onze excuses voor dit ongemak. (roughly translated: In Spooler Subsystem app an error appeared en must be shut down,...
- Mon Feb 02, 2009 1:20 am
- Topic: Adobe Photoshop Path to Inkscape?
Re: Adobe Photoshop Path to Inkscape?
I see a little window with a traffic-stop sign with the message, the file can not be opened.
Yest, jpg or pdf is possible to open in inkscape, but then it is a non-vector object. I need the path of photoshop to make a vector-drawing with it..
I hope you could help..
- Sun Feb 01, 2009 5:18 pm
I have the latest version, but when I try to open the .ai file with the path, it is not working, I get an error-message..
- Mon Jan 26, 2009 12:06 am
Goodafternoon,
Is it possible to export an Adobe Photoshop path to Inkscape? I have tried to export a path in Adobe Photoshop, but then it automatically is going to be an adobe illustrator path, and Inkscape cannot open that file,
Thank you for your help..
