Search found 4 matches
- Thu Feb 28, 2013 9:05 pm
- Topic: Curve reconstruction
Re: Curve reconstruction
Ragnar, thanks for your reply 1. Papers - I know majority of those paper (recognized just by the URLs). Closing with Delaunay triangulation seemed like the way I should go, but programming it is far from trivial, although procedure is plastically explained. 2. GIS tools - There is no GIS tool to my ...
- Wed Feb 27, 2013 4:10 pm
Hi, I have a vector generated from bitmap map trace where I segmented topological contours. These contours have gaps that were caused by various labellings, graticules and other line objects overlaid on top of contours in source bitmap. I've read couple of papers about this problem, and am aware of ...
- Fri Jun 08, 2012 1:42 am
- Forum: General Discussions
- Topic: Constant high CPU on Windows XP SP3
Re: Constant high CPU on Windows XP SP3
You were right - installer version does not have this problem for some reason, although I previously downloaded official release in 7z from Inkscape portal
- Thu Jun 07, 2012 5:49 pm
Today I downloaded latest Inkscape version in 7z archive
I started the program and noticed that just by sitting there doing nothing, it constantly uses 20-30% CPU
Why can that be?
Why can that be?
