Six Illustrations made with InkScape, on YouTube. And I made them.
http://www.youtube.com/watch?v=DiqAEbF6zQE&feature=channel_video_title
Search found 89 matches
- Thu Dec 29, 2011 6:40 pm
- Topic: Six Illustrations
- Tue May 11, 2010 12:06 pm
- Forum: Off topic
- Topic: Windows 7 or vista..?
Re: Windows 7 or vista..?
Linux should know to the users, not the other way around. Me my self never recommend Linux to people, if there are interested and want to fight the beast thats a another story. Because it's a fact, hardware comparability is a problem and that makes the marked small for a ordinary user. If it's a you...
- Mon May 10, 2010 2:01 pm
- Topic: comic book panels
Re: comic book panels
The squares in this example do not need any filling, you can set fill on the end result with white color when you have done the boolean operation. So you can work with only stroke and see the illustration under this layer, or use fill and use transparency on object or layer, it's up to you. On a lay...
- Sun May 09, 2010 10:14 am
- Forum: Work in progress
- Topic: I havent a clue, yet
Re: I havent a clue, yet
All birds have the right to have legs:)
it will bee there soon I promise.
Yes it's a thorax-
Yes it's a thorax-
- Fri May 07, 2010 3:23 pm
- Fri May 07, 2010 12:35 pm
- Topic: How to Flatten Layers Before Converting to a PDF
Re: How to Flatten Layers Before Converting to a PDF
#1 If you save the image to a Plain SVG all layer is flatten to a SVG with no layers. #2 Unlock all the layers......mark one of them...........select all object "in" the image........Object/group. All object in the image is now in a group in the layer you had selected, all the other layer...
- Sat May 01, 2010 1:57 am
- Forum: General Discussions
- Topic: Inkscape 64 bit?
Re: Inkscape 64 bit?
Why? If you have more then 3GB memory, virtual and ram including, (Win) you must have 64bit CPU and 64 bitOS. If your computer has more than 4Gb of memory, virtual and ram including, (Linux), then you need to install the 64bit CPU and 64 bitOS in order to use all the installed memory. So if you have...
- Fri Apr 30, 2010 11:39 pm
In Win you can run 32 bit InkScape on 64 bit OS. In Linux it must be writen for 64 bit to run on a 64 OS If you compile it your self you use the same code for 32 as for 64 bit, the Source Tarball. On Linux you have Inkscape in your "program central" for your 64 bit OS, probably. I have 64...
- Thu Apr 29, 2010 10:33 am
- Topic: My deviant ID image
Re: My deviant ID image
Thanks. Yes.....but, the image on the strip, on the left of the blue one with the hand, is a imported bitmap, but that to is made in Inkscape. I make many of my illustration as a kind of slow "phone Scribble". I have no plan, the ideas grows in the process of working. So when I started wit...
- Thu Apr 29, 2010 10:01 am
- Mon Apr 19, 2010 11:24 pm
- Sat Apr 17, 2010 8:38 pm
It is in a early stage. The hands, birds, women are not in there final place, scale, angle. The different “block” get the editing when I believe in the result. And maybe the women will be taken away, I don't know. This is a improvisation, and anything can happen. If I keep the women, I will do more ...
- Fri Apr 16, 2010 9:49 pm
- Sun Mar 21, 2010 10:04 pm
- Topic: Rings of Saturn
Re: Rings of Saturn
Look for "Working with Clips & Masks"
http://www.microugly.com/inkscape-quickguide/
- Sat Mar 20, 2010 4:37 am
- Topic: Inkscape can not read its own .ai file
Re: Inkscape can not read its own .ai file
Karbon14, Xara Xtreme, Skencil is other open source vector Linux program, maybe some of them can open AI, I don't know.
- Fri Mar 19, 2010 7:27 pm
- Topic: To Inkscape or not to Inkscape?
Re: To Inkscape or not to Inkscape?
"Embed" was new information for me. Thanks.
Under: Extension/Images.....Embed Images...
- Thu Feb 25, 2010 7:54 pm
- Forum: Inkscape Ideas
- Topic: Manually control border (paper)
- Thu Feb 25, 2010 6:41 pm
- Topic: Marilyn and John derived from dot shapes
- Sat Feb 20, 2010 12:42 am
- Topic: Horribly moments in world history
- Thu Feb 18, 2010 6:43 pm
- Topic: Tool Problem
Re: Tool Problem
Under File/Inkscape preferences/Tools.......Tweak................."Last used style".
I think "Last used style" is selected, so Inkscape will remember the last style you use.
Last used style is what I prefer to work with, but if you don't know about it, it's a problem.
- Sat Feb 13, 2010 7:53 pm
- Forum: General
- Topic: Guest and New User post now require approval
- Fri Feb 12, 2010 5:18 am
- Topic: Help with Letter spacing
Re: Help with Letter spacing
Try to select the text and do "Text/ Convert to text " if it doesn't work. I must do that, otherwise kerning doesn't work for me. Don't ask me why, the text is a text already but it seems to be a wake up call for Inkscape. Inkscape Tutorial by heathenx: Manual Text Kerning http://www.youtu...
- Fri Feb 05, 2010 11:08 am
- Topic: Kerning and Ligatures in Inkscape
Re: Kerning and Ligatures in Inkscape
Sorry, I don't know.
I think this problem is a typical Open Source fix: almost as it should be.
- Fri Feb 05, 2010 10:45 am
Inkscape Tutorial by heathenx: Manual Text Kerning http://www.youtube.com/watch?v=9Vr97ze75Ww Inkscape Text Tricks http://www.ffnn.nl/pages/articles/media/inkscape-text-tricks.php " Manually kerning Where the baseline affects the relative vertical position of each character, kerning is the proc...
- Wed Feb 03, 2010 7:49 am
- Forum: Tricks & Tutorials
- Topic: Gear in Inkscape
Gear in Inkscape
I have seen it over and over again in tutorial, and I have enough:)
Gear only as a circle, everywhere.
So hear me hear me; Gear in Inkscape is also a ellipse.
