I have edited a picture with Inkscape. Since it was a svg-file, it seemed the right way to do. I am a complete newbie to Inkscape but I managed pretty well.... until I uploaded the pic to Wikimedia commons:
http://commons.wikimedia.org/wiki/File:Kaart_Europa_Bondgenootschappen.svg
There is a black spot on the pic where the nation France lies. What has happened? I haven't used layers. Something must have gone wrong. Anyone?
Black spot on my svg-picture
Re: Black spot on my svg-picture
There is a 'Flowed Text' box over France that is invisible because its text has too big a font-size to be displayed within the frame.
See Bug #485269 in Inkscape: “Invisible and unselectable flow region in image” for an explanation, fix and workarounds to prevent it from happening.
removing this part from the SVG file should help:or select the visible 'Frankrijk' text object in Inkscape, then Shift+Tab once to select the previous element - in this case the flowed-text object you want to delete.
<flowRoot
xml:space="preserve"
id="flowRoot4457"
style="font-size:40px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;font-family:Bitstream Vera Sans"
transform="translate(-269.807,403.01)"><flowRegion
id="flowRegion4459"><rect
id="rect4461"
width="86.873116"
height="43.436558"
x="217.1828"
y="297.91827" /></flowRegion><flowPara
id="flowPara4463">Frankrijk</flowPara><flowPara
id="flowPara4465" /></flowRoot>
… and as one of the developers recently said:
bbyak wrote:The easy rule to remember:
when creating text, CLICK, don't DRAG.
This way you get regular text that renders everywhere (but does not reflow).
Orpheus145
Thank you for your well documented reply. I appreciate it.
