I´m using and loving inkscape. I mainly use is proffesionally for designing website´s and toher things.
For RGB use inkscape is great but it still doesn´t have good CMYK support. Sometimes it need something to be proffesionally pressed, and than i have to resort to other programs or workarround it with scribus. The PDF CMYK export plugin does not work wel on my PC.
I would love it if in future versions would be a CMYK export and proffesnional prepress option´s. Is this something to consider?
(I also worked with Adobe CS...but that´s not my taste. For one the cost is HUGE and you get to LITTLE for that money)
Good CMYK support
Re: Good CMYK support
Welcome to the forum
Since this is a users' forum (primarily) the developers who need to here your request probably won't see your message. You could check Inkscape's bug tracker at Launchpad https://launchpad.net/inkscape to find out if it's already been requested (which I suspect has probably been much requested). If you register, and once you find the report, you can click a button that says "this affects me too" (or something like that) to add your support to the request. But I really think it probably is one of the most requested new features already.
