Problem with converting svg to pdf
I also tried to convert the SVG to PDF but I am not getting the exact vector image in PDF. The image was mismatched on the PDF after conversion. I have attached the sample SVG and PDF file. Please anyone help me on this issue
- sample_svg.svg
- (3.85 KiB) Downloaded 88 times
- sample_pdf.pdf
- (1.4 KiB) Downloaded 88 times
Re: Problem with converting svg to pdf
The source for your svg uses some objects that Inkscape does not recognize: line and polygon. Converting them to paths fixes all the problems.
- sample1_svg.pdf
- (1.36 KiB) Downloaded 88 times
- sample1_svg.svg
- (4.87 KiB) Downloaded 86 times
