Is it possible to change the stroke color between selected points only?
For example: I draw a (just for ease of example) I wan to select top right and top left and change ONLY the color of the stroke between those two points.
Changing colors between points
Re: Changing colors between points
A stroke can only have multiple colours if you
- Break the stroke into separate objects
- Use a gradient
