how change make line (shift +L)?
I have a problem in change shortcuts, in my xml editor i cant find " Shift+L make line", i use ctrl+F to search for "L" but only find shortcut to layer ,so not all hotkeys are customisable or i need a specific editor?
Re: how change make line (shift +L)?
Are you talking about Edit menu > XML Editor? It sounds more like you're talking about the Inkscape canvas.
Inkscape doesn't have a Shift + L shortcut, for drawing a line (for drawing anything). Instead, Inkscape draws paths.
If you want to change some existing shortcut to Shift + L, you probably can. Look up Inkscape Preferences > Interface > Keyboard Shortcuts. Then whichever command you want to change, you can change it there.
brynn, Shift-L exists, equivalent to clicking "make selected segments lines".
Unfortunately, not all shortcuts can be changed, nor in the built-in window in Preferences, nor by editing them manually in the configs XML files. And Shift-L seems to be one of them.
Yes, for checking out shortcuts, one can always refer to: https://inkscape.org/en/doc/keys092.html
Shift +L has 3 (more or less) different meanings in Inkscape.
