I'm a c# developer. I recently purchased a plasma cutter and have been using inkscape to design some of my cut files. I ran into an issue with the save as dxf, where its scaling incorrectly. I have to multiple my size by aprox 37.98 to get it close to the original size in inches. I've read a few posts about this being an issue in the share/extensions/dxf_outlines.py file. I've taken a look and would like to run it in debug mode to see if I can take care of it. I think I can visual code to debug the file, just need a push in the right direction. Any links on how to debug python files would probably be a good start.
thanks
Jason
Help get started debugging python
Re: Help get started debugging python
I can't help with debugging, but this may be helpful for the scale issue... a bug has been fixed for the next release and the related extension can be downloaded for use with the current version.
https://bugs.launchpad.net/inkscape/+bu ... comments/3
