I am learning how to write svg graphics in notepad but I have reached a problem that doesn't seem to make any sense and I can't get past.
If I have a rect and write a property of height="75" it works but if I write style="height:75;" instead it doesn't work (ie. the rect disappears, most likely because it has no height).
But if I write fill="red" it works and if I write style="fill:red;" it also works
Do some properties have different names when used in a stylesheet or inline styles as opposed to directly in the svg code?
<rect class="rect1" x="50" y="100" width="400" height="75" fill="red" /> - Works
<rect class="rect1" x="50" y="100" width="400" style="height:75;" fill="red" /> - Doesn't work (no rectangle displaying)
Some things seem to work in both stylesheets/inline styles and directly written in svg and others don't.
For further examples: stroke and stroke-width work in both but preserveAspectRatio doesn't work in style form.
Some properties in stylesheet/inline stlye form don't work?
Vectorator
Re: Some properties in stylesheet/inline stlye form don't wo
If you have problems:
2.- Please check here:
Vectorator
Ok thanks, that is a much more in depth tutorial.
I have already found a solution to another issue in chapter six.
I had read another tutorial which didn't cover many of these things.
