Hi I'm new to Inkscape and I am trying to set line width to 0.01 mm as recommended by Ponoko for laser cutting.
but when I do this the object becomes invisible.
I am doing this in stroke style width
the lowest I seem to be able to get is 0.1, I can type in a value less than this but then the object is gone.
Any help would be appreciated.
when setting linewidth = .01mm object disappears
warwickbeer
Re: when setting linewidth = .01mm object disappears
You can see the lines by changing to Menu:View>Display Mode>Outline.
You could also zoom way in, but of course it would be hard to see the whole drawing.
warwickbeer
thats what I needed thankyou!
