I've always had difficulty with snapping, in Inkscape. I'm not sure why, other than not understanding the settings. Well, I should say that I think I understand them, but my choice of settings never results in snapping as I want. So maybe I'm confused about the language. In 0.46, the Snap To settings language is much more clear than in my previous version, 0.44. But again, even though I think I understand them, I can't seem to configure the settings to snap as I want.
Anyway, I just noticed something in 0.46, that does not happen in my 0.44 version. Maybe it's a bug, or maybe discussing it will lead to a better understanding on my part.
Whenever I enable snapping, it snaps to the grid, even if I have NOT selected Snap to Grid. If I choose to snap Nodes, the nodes snap to the grid. If I choose to snap bounding boxes, the b-boxes snap to the grid. The grid snapping is so strong that I can't use any other snapping, because the grid snapping interferes. The only way to stop snapping to the grid is to disable the grid.
Oh! I do know about disabling snapping by holding down the Enter key, and that DOES disable the grid snapping. (It does NOT disable snapping of node handles, but I don't think it's supposed to....although it would be nice if it did.) But it's kind of tricky to use, for me -- you can't hit the Enter key before you start moving whatever it is you're moving (if you do, it starts rubberband selecting). You have to start moving the mouse, and hit the Enter key while it's moving, which I find kind of awkward.
I suppose that disabling the grid can easily be done at the same time I enable snapping when I need it. But again, maybe I just don't understand, or maybe it's a bug that I should report.
Is this grid snapping which can't be diasbled (except by disabling the grid altogether) expected or known? Or is there something I can do about it?
Thanks for any comments
All best.
