pattern-fill difficulty
No problem using one of my patterns to fill any and all Inkscape shapes that you find on the left side. It is when trying to fill exterior shapes (for instance, a country outline) that I find it impossible to do, even though I made sure to "trace bitmap" it. The same difficulty occurs whether using ING or SVG. I am certain that my query will find enlightening responses because my searches have not discovered a similar problem.
Re: pattern-fill difficulty
Would be best if you can provide an example svg file. Embed or include the bitmap file. Please use a link to a sharing/hosting service if the file is too large.
The most likely scenario is that your shape is an outline which looks stroked but is actually a filled stroke. The center area will always be empty because it is not the interior of any shape. This happens whenever one tries to trace a picture with an outline instead of a solidly colored region. The trace bitmap routine in Inkscape does NOT recognize outlines (yet).
PS Not sure what ING format is, assuming a typo... for PNG?
Here are two files for you to peruse: the base image France.jpg and the file destined to become a pattern
Eiffel.png. I'll be curious to know what you have been able to do or advise me to do. Thanks so far.
Oh, ING was a typo for PNG.
- eiffel.png (17.29 KiB) Viewed 1555 times
- france.jpg (84.58 KiB) Viewed 1555 times
I'd suggest you try to find a non-copyrighted vector version of France, instead of doing trace bitmap on a jpg.
If you want to use the traced version, though, select France, then do 'Path > Break Apart', then 'Path > Union' (without deselecting in between).
See if you can figure out from this path added on top of the trace of your jpg. In the trace bitmap dialog you can uncheck the stack scans option although that's not how I went about it
- lafrance.svg
- (158.26 KiB) Downloaded 166 times
I have discovered a surprising solution while awaiting your comments: When I did a "trace bitmap" with edge detection on the country, the outline became thicker. So this Inkscape novice deduced that the area it encompassed would be filled easily. Error! Yet, with several trials done, I noticed at times that this outlline seemed to take on a faint tint. Why this focus on outlines instead of body I thought. It occurred to me that pattern-fill did not fill the body but the stroke. why would that be? Anyway, I did a little experiment, clicked on the bucket then on the country. That was no problem because the interior (the white part) immediately filled with the default color blue. With that new look untouched I clicked on Fill & Stroke's pattern-fill and, surprise, the country was immediately filled with my pattern. To continue, I thought that there was no reason for a preliminary fill with color but alas no I had to rely on this little subterfuge. At least I had found one kind of solution. In the end, I have two questions: why do the bucket fill first and, how is Inkscape able to distinguish the color white from the area around it.
I am showing you an example with the attached file of Andorra and a penguin.
- andorrapenguin.svg
- (208.95 KiB) Downloaded 175 times
