I've found how to cut vinyl with inkscape - finally.
Now, Inkscape has updated and my previous method doesn't work. So I downgraded and did it the way I did before.
Select 'Print' , then in the box that comes up paste the following:
| /home/bruce/hpgl/print-to-cutter.sh
that is a nice shell script for using a knife plotter
The newest Inkscape uses the system printer settings, so the little box no longer comes up.
How do I create a "Pipe" printer?
new inkscape changed printer - need pipe!
brucewestfall
Re: new inkscape changed printer - need pipe!
I know nothing about this, but you might like to look at using the command line.
