The 1 extension for creating a table: http://sourceforge.net/projects/inkscape-tables/
appears not to be for OSX. Is there an extension for Macs?
Create table
Re: Create table
Off the top of my head, I'm not sure. But I keep a list of all known (external) extensions on this page: https://forum.inkscapecommunity.com/index.php
In the Extensions section (bottom third of the page) and in the 3rd box, click on "Render". Then scroll down to the "Tables, Charts, Graphs, Plots" section. It looks like there's at least one other extension for making tables. I'll keep my fingers crossed for you!
Re: Create table
From the About:
<snip>...
This extension is tested only on Ubuntu 11.04, but normally should
work on any platform on which Inkscape works. Being written in
Python, there shouldn't be any problem with it.
Re: Create table
What's with the extension that is included in Inkscape? Extensions > Render > NiceCharts.
Re: Create table
I have (supposedly) installed the Extension (http://sourceforge.net/projects/inkscape-tables/) and re-launched Inkscape but can't see it within the Extensions menu.
When I run the installation I get:
Last login: Tue Nov 27 20:19:10 on ttys000
/Users/stephen/Downloads/inkscape-table-1.0/install ; exit;
Stephens-MacBook:~ stephen$ /Users/stephen/Downloads/inkscape-table-1.0/install ; exit;
/Users/stephen/Downloads/inkscape-table-1.0/install: line 3: inkscape: command not found
usage: cp [-R [-H | -L | -P]] [-fi | -n] [-apvX] source_file target_file
cp [-R [-H | -L | -P]] [-fi | -n] [-apvX] source_file ... target_directory
/Users/stephen/Downloads/inkscape-table-1.0/install: line 5: inkscape: command not found
/Users/stephen/Downloads/inkscape-table-1.0/install: line 5: ./install_shortcuts.py: No such file or directory
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
It seems to complete OK.
BTW, where is the Inkscape Extensions folder kept? Again, I've not located this in OSX.
logout
Saving session...
...completed.
[Process completed]
Re: Create table
Instructions for installing extension: https://inkscape.org/learn/faq/#how-ins ... n-sets-etc
Moini, would an extension called Nice Charts make tables?
Re: Create table
Thanks. My User Config is apparently: /Users/stephen/.config/inkscape
However, the "/.config/inkscape" part doesn't exist and OSX doesn't permit "." before a folder name.
So I'm still a bit stuck.
Re: Create table
No, it doesn't. i confused it with the tables extension that I have.Moini, would an extension called Nice Charts make tables?
Re: Create table
tays01s wrote:Thanks. My User Config is apparently: /Users/stephen/.config/inkscape
Edit - My bad. I misread the faq
I'm not sure what that period means, but I might be inclined to ignore it, and install the extension there anyway.
(Actually I've seen that period added to file names in my server which uses a linux system. I never have figured out what it means. But the file always exists without it too, so at least so far, ignoring it works ok.)
Re: Create table
It's a hidden directory. Even on OS/X.
https://apple.stackexchange.com/questio ... -in-finder
Re: Create table
That explains why I can't see it. However, what do I do to get the Extension into the correct folder.
I assume once there Inkscape can then access it.
Re: Create table
Sorry, I'm not on a Mac, you may need to use google or another search machine of your choice.
