I don't know if it's the best place to ask this, but I'm new on this forum and I'm French so...I have to concentrate myself to read en write. I'm sorry if I do some spellings...
But my problem is that I have a problem when I want build Inkscape on my PC (with Windows 7). I follow these instructions : http://wiki.inkscape.org/wiki/index.php/Win32Port But the last act (C:\src\inkscape\trunk> btool) don't work
============ cmd ============
mingw32-g++ -c -Wall -Wformat -Werror=format-security -W -Wpointer-arith -Wcast-
align -Wsign-compare -Woverloaded-virtual -Wswitch -O2 -mms-bitfields -fopenmp -
DVERSION=\"0.47+devel\" -DHAVE_CONFIG_H -D_INTL_REDIRECT_INLINE -DHAVE_SSL -DREL
AYTOOL_SSL="static const int libssl_is_present=1; static int __attribute__((unus
ed)) libssl_symbol_is_present(char *s){ return 1; }" -DPOPPLER_NEW_GFXFONT -I. -
Ic:\devlibs/include -Ic:\devlibs/include/gtkmm-2.4 -Ic:\devlibs/lib/gtkmm-2.4/in
clude -Ic:\devlibs/include/glibmm-2.4 -Ic:\devlibs/lib/glibmm-2.4/include -Ic:\
devlibs/include/glib-2.0 -Ic:\devlibs/lib/glib-2.0/include -mms-bitfields -Ic:\d
evlibs/include/sigc++-2.0 -Ic:\devlibs/lib/sigc++-2.0/include -Ic:\devlibs/inclu
de/giomm-2.4 -Ic:\devlibs/lib/giomm-2.4/include -Ic:\devlibs/include/gdkmm-2.4
-Ic:\devlibs/lib/gdkmm-2.4/include -Ic:\devlibs/include/pangomm-1.4 -Ic:\devlib
s/lib/pangomm-1.4/include -Ic:\devlibs/include/gtk-2.0 -Ic:\devlibs/lib/gtk-2.0/
include -Ic:\devlibs/include/gtk-2.0 -Ic:\devlibs/include/pango-1.0 -Ic:\devlibs
/include/pango-1.0 -Ic:\devlibs/include/pango-1.0 -Ic:\devlibs/include/cairo -Ic
:\devlibs/include/cairomm-1.0 -Ic:\devlibs/lib/cairomm-1.0/include -Ic:\devlibs/
include/atkmm-1.6 -Ic:\devlibs/include/atk-1.0 -Ic:\devlibs/include/gtk-2.0 -mms
-bitfields -Ic:\devlibs/include/gtk-2.0 -Ic:\devlibs/lib/gtk-2.0/include -Ic:\de
vlibs/include/ImageMagick -Ic:\devlibs/include/ImageMagick -fopenmp -D_MAGICKDLL
_ -Ic:\devlibs/include/libxml2 -Ic:\devlibs/include/freetype2 -Ic:\devlibs/inclu
de -Ic:\devlibs/include/cairo -Ic:\devlibs/include/poppler -Ic:\devlibs/include/
gc -Ic:\devlibs/include/libwpg-0.1 -Ic:\devlibs/include/libwpd-0.8 -Ic:\devlibs/
include/libwpg-0.1 -Ic:\devlibs/include/libwpd-0.8 -Icxxtest -Ic:\devlibs/python
/include -Isrc/bind/javainc -Isrc/bind/javainc/win32 -Isrc -Isrc/2geom -Isrc/2
geom/numeric -Isrc/application -Isrc/bind -Isrc/debug -Isrc/dialogs -Isrc/displa
y -Isrc/dom -Isrc/dom/io -Isrc/dom/odf -Isrc/dom/util -Isrc/extension -Isrc/exte
nsion/implementation -Isrc/extension/internal -Isrc/extension/internal/bitmap -I
src/extension/internal/filter -Isrc/extension/internal/pdfinput -Isrc/extension/
script -Isrc/filters -Isrc/helper -Isrc/io -Isrc/jabber_whiteboard -Isrc/jabber_
whiteboard/dialog -Isrc/libavoid -Isrc/libcola -Isrc/libcroco -Isrc/libgdl -Isrc
/libnr -Isrc/libnrtype -Isrc/libvpsc -Isrc/libvpsc/pairingheap -Isrc/livarot -Is
rc/live_effects -Isrc/live_effects/parameter -Isrc/pedro -Isrc/svg -Isrc/trace -
Isrc/trace/potrace -Isrc/ui -Isrc/ui/cache -Isrc/ui/dialog -Isrc/ui/tool -Isrc/u
i/view -Isrc/ui/widget -Isrc/util -Isrc/widgets -Isrc/xml src/xml/subtree.cpp -o
build/obj/xml/subtree.o
Make error line 299: problem compiling: cc1plus.exe: error: unrecognized command
line option "-Werror=format-security"
cc1plus.exe: error: unrecognized command line option "-fopenmp"
Can you anderstand why I can't build it ?
I need your help, I thank you if you answer me
