But when i save as in pdf format and open it with acrobat the print out is very well.İn this point can i change inkscape the code which is under the print menu.For example i want to do when the user clıck prınt firstly inkscape save as pdf format after that print command will be active.İs it possible if it is pls describe me because we want to delivery all the florist in turkey.pls help me print out problem. sorry for very bad english
print out problem pls help me
we r write a program for florist.Our paper sizes r weight 1200 height 150.When we r try to print the print out looks like a4 size.
Re: print out problem pls help me
So, your question is: when you print from Inkscape, can Inkscape both print the image and create a PDF version? The answer is no, this is not something Inkscape can do.
If you're using Linux you might be able to script something but I couldn't give you an answer for how.
