Hi guys!
I wanted to send some stuff to laser cut, and I'm facing a problem. The laser cutter service I'm using has a certain precision, and requires me to eliminate all the features that are smaller than a certain size. I was wondering if there is a plugin or a tool that let's me, say, select all the features that are smaller than X mm, or lines that are closer to X mm one another, in order to detect those features. Normally, they are just tiny details that will simply not appear on the finished pieces, so not a big deal, but in some cases they could affect the appearance of what I am looking to get.
If you have any ideas, it would be great to hear them.
Cheers!
Find features smaller than a certain size
Re: Find features smaller than a certain size
That's a tough one.
Only know of a brute-force solution, that theoretically can work in some cases.
It's outsetting and insetting after with the same amount.
It eliminates small parts, but works sloppy too many times.
That's a tough one.
How large is this file? How was the file created, that resulted in so many tiny objects? Maybe there's a better way to create the file?
Resurrecting this older topic as it is still an issue.
It would be great to have a find/select by size tool. Any word on an extension that selects objects greater than or less than a specified H or W?
More folks are using Inkscape for lasers, and some tiny objects can freak out the laser drivers. These objects can result from auto-tracing or poorly executed path operations and even mis-clicking with a drawing tool.
Attached is an example with a small object that would stop a laser job midway. (Might actually be a malformed object, but a tool to select tiny objects would have caught it.)
- Hidden_Segment.svg
- (13.77 KiB) Downloaded 265 times
Well auto tracing is what I was getting at with my questions. There is an option on the Options tab of Trace Bitmap dialog, where you can ignore stray marks of a certain size, in the trace. Its called Suppress Speckles. Or else there might be options on the scanner which brings a drawing into the computer, to reduce stray marks.
On the one hand, finding that tiny object doesn't seem so hard to do. But on the other hand, this sounds like a nice job for some industrious extension maker!
Sorry, I don't know of any such extension. I'm also probably not creating any new ones for Inkscape < 1.0, and I won't create extensions for 1.0 before I know how to do it, and before the API is stable.
Well, I'm going to accept that it's possible, but might be long on the wishlist.
Plus, there is a high likelyhood an extension like that could lead to even more problems. Consider an imported file from CAD that has all the curves made from tiny straight segments... Inkscape can take a long time to select thousands of objects.
I'd make these options available:
select by area yes/no (checkbox)
max. area size
select by length yes/no (checkbox)
max. length
consider subpaths as separate objects
delete (this is useful for the subpaths option, will keep the rest of the path intact)
select only (subpaths are ignored or maybe separated out of their original objects)
