Hi Friends,
I was just answering a message here: viewtopic.php?f=27&t=1904&p=103029#p103029 about attachment limits. So I'm just posting this so I can attach a large image. Then I'll check my control panel.
I suspect when we reach the limit, older attachments are automatically deleted. Because I can't imagine, since Nov 2008 I haven't posted 50 mb worth yet.
Hhmm....having trouble finding a small enough file, to avoid the error message: File too large. There's no clue whether it means the single file is too large, or if I've finally reached my 50 mb limit.
Now testing 405 kb....moving on down to 321 kb....to... Ok 281 kb too large, but 250 kb is accepted
testing attachment limits
- e2.png (249.37 KiB) Viewed 843 times
Re: testing attachment limits
Nothing deleted from control panel.
Ooohhh, I just found the file size! It does give the file size, just not in a convenient column. It would be tedious, but I could use a calculator....
I'm thinking the single upload limit must be 250 kb. I'll try the calculator.
Actually I've found a PDF I uploaded 350 kb....
an SVG 471 kb....
strange....
an SVG 471 kb....
strange....
