I have not been able to duplicate the
example in the Inkscape Manual, Generate from Path Chapter, the Text on
Path, single, stretched ribbon option. It is at the bottom of that page.
http://tavmjong.free.fr/INKSCAPE/MANUAL ... omPathText
When I done all the steps, a pop up box with Python.exe comes up and
appears to be trying to turn my text object into the ribbon path, but
nothing happens. I had no problem with the Spiral and Text on Path.
Has anyone been able to do the text on path, single stretched ribbon
option. I would appreciate a step by step tutorial!!!
[solved] ribbon text in Generate from path
Re: ribbon text in Generate from path
Just tried it and it worked as expected for me - you did convert the text to a path first? Select both paths, the text first ....only things I can think of where it might have went wrong...
Tutorial if needed
Tutorial if needed
Neil
Are you using the current stable build (0.45) or an SVN (development version)? I know this effect hasn't worked properly in past SVN's.
- Darth_Gimp
- Contact:
Worked fine here too...
* write text
* make path
* convert text to path
* select text then path
* apply effect with Single, Stretched and Ribbon
* done.
* write text
* make path
* done.
novice
Thanks for the replies and especially the Two Minute Tutorial which was invaluable! I can see now what I was doing wrong. Made my day.
novice wrote:Thanks for the replies and especially the Two Minute Tutorial which was invaluable! I can see now what I was doing wrong. Made my day.
Was it not converting to a path....took me a while to figure that out when I first used it....I should read the manual hehehe
Neil
novice
Sometimes reading the manual only makes sense AFTER you've struggled through a project by trial and error, or get help on a 1:1 basis in a forum. At least I know where to go with my next Inkscape hiccup.
novice wrote:Sometimes reading the manual only makes sense AFTER you've struggled through a project by trial and error, or get help on a 1:1 basis in a forum. At least I know where to go with my next Inkscape hiccup.
Glad you got it working
BTW - are you registered on the forums or posting as a guest??
Neil
novice
I am posting as a guest - is there any difference between a guest and being registered?
novice wrote:I am posting as a guest - is there any difference between a guest and being registered?
As far as gneral communication on the forum, no. I wanted to keep the forum open to people who are unwilling to register to a forum that has limited activity.
There are some advantages to registering though. You can send and recieve private messages. You can recieve e-mail notification when someone replies to a topic you've subscribed to. And a bunch of other features. You can also enter and vote in the competitions. If you intend on being a regular visitor it's a good idea to register so we know who we are talking to. Anyone could pretend to be you if you're not registered.
