I have a circle. I also have two lines leading to the circle. I want to erase the small area of circle between the two lines so it is welded together instead of cutting the circle off. How on earth do I do this?!
The erase tool either erases the whole object or the part of the circle i want but then puts in a new line.
The node edit doesn't work as the circle drawn in inkscape doesn't seem to have nodes in that area.
