Problem with image and border.
JonathanTheMaker
So i got a template i got from a website (did the vector thing), and use the object>cut>set thingy. I want to make an outline, but i cant please help!!!!
Last edited by JonathanTheMaker on Sun Sep 09, 2012 3:08 pm, edited 1 time in total.
Re: Help me!!!
OMG! Red Alert!!
What kind of template? From what website? What is a "vector thing"? What is "object>cut>set thingy"?
JonathanTheMaker
Re: Help me!!!
the thing where you can crop an image. it was bitmap but i converted it to vector. I cropped a circle so that one side had a design and another did not. i tried to put an outline on the outside, but i dont know how. it was like a half gear thing
Re: Help me!!!
I'm still not at all clear what you're doing. Are you following a tutorial? If so, can you give us a link?
The place where you want an outline, is that the same as the clipping path? If so, you could unclip it, duplicate the clipping path, and re-clip it. Then there will be an outline.
If that doesn't work, try selecting it and adding a stroke (Object menu > Fill and Stroke > Stroke Paint tab > Flat color button (2nd from left). If that doesn't work, try drawing one using either Pen/Bezier or Pencil/Freehand tool.
If that doesn't work, maybe you could show us a screenshot? (viewtopic.php?f=6&t=11753) In the end, I may need to see the SVG file. Or maybe someone else understands??
JonathanTheMaker
Re: Help me!!!
UPDATE!!!
YOU HAVE SAVED MY LIFE YOUNG MAN!!!!
DDDDD
THANK YOU SOOO MUCH!!!!
Last edited by JonathanTheMaker on Sun Sep 09, 2012 2:38 pm, edited 1 time in total.
Re: Problem with image and border.
Wow!
Ok then, you're welcome
At least I'm young this time though
just testing
Off topic:
druban, my flower doesn't seem to be working Edit
just testing
Off topic:
Maybe you shouldn't have used a SON-flower?brynn wrote:druban, my flower doesn't seem to be working At least I'm young this time though
Off topic:
. Basics - Help menu > Tutorials
