I am new to Inkscape. First of all, I would like to thank the developers for making such an amazing program
So, I'm trying to make a spider diagram/mind map (http://en.wikipedia.org/wiki/Mind_map) for outlining European history. Inkscape seems to be well-suited for this, especially the Connector tool. I want to add text to connectors between two objects so that when I move one of the two objects, the text moves (and rotates, if possible) with the connector path. I also want to be able to reposition the text along the path. I can do the first part with "Put on path" in the "Text" menu, but if I adjust the position and orientation of the text after I put it on the path, it doesn't move correctly with the connector when one of the connected objects moves. Is there a good way to do this? Thanks!
